> Orange 75 project, Clutch and Shifter setup
my928s4
post Nov 25 2007, 03:13 PM
So a couple months back I posted about getting a hold of the project candidate,
feel like I have moved on from that so thought it I would post some pics on progress and I will add to this thread as time (and progress) goes on.
I did not get around to stripping the car down till earlier in the month as I drove my 928 down to Sharktoberfest in LA and I was performing last minute tinkering before the drive.
Anyway back to 914 subject matter, the good news is I have not found too many issues which is a relief and I can start to order parts and make some investment in tools. It is a perfect time of year for indoor projects as it is below freezing all the time now and skiing does not start here till after xmas.
Surface rust and dirt in the front trunk but that is about it, will need to repiar a couple of areas around the hood seal.
Chris
charliew
post Oct 28 2008, 12:47 AM
Your work looks really good for your experience level. Hot metal in the socks is tough. A pair of wolverines boots would help. Harbor Freight has a cheap leather apron. If you can find a metal salvage yard, you might look for some pieces of copper. I have some 3/8 thick 4x4 square copper plates that I put behind single wall panels and weld holes up against the copper plates. The wire won't stick to the copper and the back side is flat when you finnish. Eastwood has some expensive copper helpers that are magnetic. Some weld through primers can be removed with laquer thinner. You can use a qtip with laquer thinner to clean out the holes in the stiffeners, it dosen't take but a second for each hole. Also you may not think you need it but Eastwood has a long air powered 4 inch cutoff wheel tool that is real handy. I use the 1/16 thick wheels on everything from metal to fiberglass. It would be a good xmas present for your wife. A carbide burr on a air tool will get in the corners on the welds. Restomotive also sells a Tiecoat primer that will stick to the por15. It's babyblue so you might want to paint over it. It's hard to get normal paint and glue to stick to por15.
I am wondering if the Engman kit made the door gaps change any.
I think it should be against the law to have that much fun by yourself.
my928s4   Orange 75 project   Nov 25 2007, 03:13 PM
my928s4   Interior needs a bit more work, car was in Seattle...   Nov 25 2007, 03:16 PM
my928s4   Some more surface rust around the pedals but every...   Nov 25 2007, 03:20 PM
my928s4   Despite prodigous prodding with a large screwdrive...   Nov 25 2007, 03:24 PM
orthobiz   I love orange! Keep posting progress and good ...   Nov 25 2007, 08:16 PM
Dan (Almaden Valley)   save the orange cars :D keep up the good work......   Nov 25 2007, 08:23 PM
9146FAN   :agree: Orange is the best. Looking good!   Nov 25 2007, 10:04 PM
my928s4   OK got a couple of hours in yesterday and today wi...   Dec 30 2007, 02:30 PM
my928s4   The bad The good   Dec 30 2007, 02:35 PM
my928s4   Messed up.   Dec 30 2007, 02:37 PM
scotty b   rear pan section is definitely needed. IMHO that s...   Dec 30 2007, 05:18 PM
my928s4   B)-->
QUOTE(scotty b @ D...   Dec 30 2007, 07:13 PM
my928s4   B)-->
QUOTE(scotty b @ D...   Dec 30 2007, 09:17 PM
McMark   I would section in the rear pan, not do a complete...   Dec 30 2007, 10:59 PM
my928s4   So while making progress with the grinder and wire...   Jan 13 2008, 05:51 PM
my928s4   And then a 2nd coat, looked pretty good so I will ...   Jan 13 2008, 05:55 PM
my928s4   OK, couple of questions. What should I do with th...   Jan 13 2008, 05:59 PM
scotty b   IMO the jack post should ALWAYS be cut out as they...   Jan 13 2008, 06:48 PM
my928s4   B)-->
QUOTE(scotty b @ J...   Jan 14 2008, 08:36 AM
finstermojo   When i did my resto and did the same thing you are...   Jan 13 2008, 08:12 PM
my928s4   When i did my resto and did the same thing you ar...   Jan 14 2008, 08:40 AM
sixaddict   Thanks for post on rust bullet info. I asked a wel...   Feb 8 2009, 04:05 AM
my928s4   Thanks for post on rust bullet info. I asked a we...   Feb 12 2009, 09:12 PM
my928s4   Still waiting for the rear pan (should be here nex...   Jan 27 2008, 11:44 AM
Root_Werks   I have seen many-o-914's and your's is not...   Jan 27 2008, 06:54 PM
my928s4   I have seen many-o-914's and your's is no...   Jan 27 2008, 07:24 PM
my928s4   Cleaned up the battery area in the engine bay when...   Jan 27 2008, 07:31 PM
bandjoey   In the Jan 13 post you've just finished cleani...   Jan 27 2008, 08:25 PM
my928s4   In the Jan 13 post you've just finished clean...   Jan 27 2008, 10:17 PM
my928s4   OK so still waiting for the floor panel so I decid...   Feb 3 2008, 09:08 PM
my928s4   OK so still waiting for the floor panel so I decid...   Feb 3 2008, 09:09 PM
my928s4   Here are the two holes after grinding.   Feb 3 2008, 09:13 PM
my928s4   So bumper shock holes are now done, last one went ...   Feb 9 2008, 04:50 PM
my928s4   OK now onto the BIG job of the day, the floor pan ...   Feb 9 2008, 04:53 PM
my928s4   Got the wire wheel attachment on the grinder and d...   Feb 10 2008, 04:44 PM
my928s4   Another weekend lying mainly under the car, I thou...   Feb 17 2008, 09:22 PM
my928s4   I ordered some seat mount hinges from restoration ...   Feb 17 2008, 09:25 PM
jim912928   Excellent progress!   Feb 17 2008, 10:24 PM
my928s4   OK, spent some serious time on the car yesterday a...   Feb 24 2008, 06:39 PM
my928s4   Well it has been a while, had a never ending honey...   May 24 2008, 10:11 PM
my928s4   After grinding and 120 grit sander Passenger si...   May 24 2008, 10:13 PM
my928s4   Antenna hole, this one did not come out as well .....   May 24 2008, 10:17 PM
my928s4   Finally the drivers side, I posted pics of the rus...   May 24 2008, 10:20 PM
my928s4   It has been a while, this summer I spent doing oth...   Oct 26 2008, 11:05 AM
my928s4   Two new rear jack points were welded in. Here y...   Oct 26 2008, 11:09 AM
plymouth37   Nice project! You are well on your way to a gr...   Oct 26 2008, 12:32 PM
Gint   :agree: You're doing some nice work there. K...   Oct 26 2008, 12:51 PM
my928s4   Thanks for the words of encouragement, learning a ...   Oct 27 2008, 11:08 PM
9146986   After you tack the perimeter of the stiffening pla...   Oct 28 2008, 12:10 AM
Cheapsnake   Very nice work there and an inspiration to those o...   Oct 28 2008, 09:56 AM
blabla914   good looking work. Lots of hard, dirty work to ma...   Oct 28 2008, 12:02 PM
bandjoey   Now that it's many moons since the first coat ...   Oct 28 2008, 10:53 PM
my928s4   After you tack the perimeter of the stiffening pl...   Oct 29 2008, 07:59 AM
watsonrx13   BTW, if you can't find the copper plate, go to...   Oct 29 2008, 12:33 PM
my928s4   After removing the undercoating I printed the temp...   Nov 2 2008, 06:36 PM
my928s4   Last but not least I removed the front suspe...   Nov 2 2008, 06:39 PM
Todd Enlund   Last but not least I removed the front suspension...   Nov 29 2008, 02:34 PM
bigkensteele   Please tell me that you are independently wealthy,...   Nov 2 2008, 11:02 PM
my928s4   Please tell me that you are independently wealthy...   Nov 29 2008, 01:24 PM
my928s4   I was going to leave most of the underside which I...   Nov 29 2008, 01:32 PM
3d914   Chris, Excellent job, and you're making great...   Nov 29 2008, 03:49 PM
my928s4   I am curious about a couple of things. What type...   Nov 29 2008, 04:49 PM
Lou W   Chris, You're doing a great job, keep up the ...   Nov 29 2008, 11:42 PM
my928s4   Another long break but work has been progressing, ...   Feb 7 2009, 10:25 PM
sendjonathanmail   Looking good man, keep the pics and the progress c...   Feb 7 2009, 10:33 PM
my928s4   So this week I decided to attach the flares as I n...   Feb 7 2009, 10:36 PM
Todd Enlund   So this week I decided to attach the flares as I ...   Feb 8 2009, 02:14 AM
my928s4   I bought a HF blasting cabinet and have been clean...   Feb 7 2009, 10:40 PM
PanelBilly   You've been busy. Looks good.   Feb 8 2009, 01:35 AM
my928s4   OK, finished tack welding the rear flares. G...   Feb 12 2009, 09:17 PM
my928s4   I am finished (or hope I am) welding on the 1st fl...   Feb 22 2009, 05:23 PM
charliew   POR 15 has a tiecoat primer, it's baby blue co...   Feb 26 2009, 11:26 PM
my928s4   POR 15 has a tiecoat primer, it's baby blue c...   Mar 15 2009, 01:05 PM
my928s4   Got some parts plated, calipers came out crap so a...   Mar 15 2009, 01:13 PM
my928s4   Still working on the fenders, got the third (passe...   Mar 15 2009, 01:17 PM
charliew   One things for sure Chris, you aren't afraid o...   Mar 15 2009, 11:52 PM
al weidman   Chris, I have the HF bead blast cabinet and am usi...   Mar 16 2009, 09:00 PM
my928s4   One things for sure Chris, you aren't afraid ...   Mar 16 2009, 09:42 PM
al weidman   Chris, I also got the small vacuum system from HF ...   Mar 16 2009, 09:46 PM
914Tom   :popcorn:   Mar 17 2009, 03:16 AM
nsr-jamie   I love this post!! Awesome!! Keep ...   Mar 17 2009, 05:42 AM
Phoenix914   I just read through this entire thread. What a fa...   Mar 17 2009, 07:10 AM
my928s4   Went back to the local paint and supply shop and p...   Mar 20 2009, 07:08 AM
my928s4   After the failed experiment with the Schutz I boug...   Mar 20 2009, 07:12 AM
Kansas 914   After the failed experiment with the Schutz I bou...   Mar 20 2009, 07:20 AM
dakotaewing   I'll be doing the same with my project shortly...   Mar 20 2009, 09:01 AM
914Tom   why not apply a PVC coat and paint the underside a...   Mar 20 2009, 11:05 AM
my928s4   How many cans did you use to coat the underside? ...   Mar 20 2009, 11:50 AM
my928s4   Well not too much to report, I took a 3 week break...   Apr 19 2009, 02:24 PM
charliew   You might want to check out a caliper rebuild thre...   Apr 19 2009, 05:19 PM
my928s4   You might want to check out a caliper rebuild thr...   Apr 20 2009, 09:03 AM
MDG   Chris, just finished reading through this thread; ...   Apr 20 2009, 04:43 PM
my928s4   Chris, just finished reading through this thread;...   Apr 20 2009, 06:52 PM
my928s4   At last the lowest part of the car is done, the 2n...   Apr 25 2009, 04:43 PM
Lou W   Sure looking good, very nice job. :beer2:   Apr 25 2009, 08:34 PM
Slider   Nice job Chris, keep up the good work you are an i...   Apr 25 2009, 10:13 PM
charliew   I held my fg rocker from aa up to my 75 body and I...   Apr 26 2009, 09:39 PM
my928s4   Not too much going on but took some parts to the p...   May 5 2009, 07:01 PM
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 3rd April 2025 - 01:43 AM
