SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
so, the H4 Headlight Upgrade Kit on pelican recommends a high-power relay for the 100 watt bulbs.
now the stupid question: do i just need one or do i need one for each headlight? (IMG:style_emoticons/default/idea.gif) Andy |
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
Mine are the housing with replaceable bulbs. Hella has a nice glass one, there are some cheap plastic ones on ebay, which I have heard suck.
Hella H4 If you go with the 100w bulbs you'll need to get power straight from the battery as the fuse panel can't handle it. The original power lead for the headlights, becomes the switch for the relay. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Mine are the housing with replaceable bulbs. Hella has a nice glass one, there are some cheap plastic ones on ebay, which I have heard suck. Hella H4 If you go with the 100w bulbs you'll need to get power straight from the battery as the fuse panel can't handle it. The original power lead for the headlights, becomes the switch for the relay. What size wire did you use? Did you run four new wires??? I understand the relay wiring using the stock setup...got that. Rich |
Lo-Fi Version | Time is now: 20th June 2024 - 09:07 AM |
