H4 Headlight upgrade ..., stupid question ... |
SirAndy |
Nov 13 2006, 06:51 PM
Resident German Group: Admin Posts: 41,806 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so, the H4 Headlight Upgrade Kit on pelican recommends a high-power relay for the 100 watt bulbs.
now the stupid question: do i just need one or do i need one for each headlight? (IMG:style_emoticons/default/idea.gif) Andy |
blitZ |
Oct 29 2008, 10:42 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Mine are the housing with replaceable bulbs. Hella has a nice glass one, there are some cheap plastic ones on ebay, which I have heard suck.
Hella H4 If you go with the 100w bulbs you'll need to get power straight from the battery as the fuse panel can't handle it. The original power lead for the headlights, becomes the switch for the relay. |
r_towle |
Oct 29 2008, 12:00 PM
Custom Member Group: Members Posts: 24,623 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Mine are the housing with replaceable bulbs. Hella has a nice glass one, there are some cheap plastic ones on ebay, which I have heard suck. Hella H4 If you go with the 100w bulbs you'll need to get power straight from the battery as the fuse panel can't handle it. The original power lead for the headlights, becomes the switch for the relay. What size wire did you use? Did you run four new wires??? I understand the relay wiring using the stock setup...got that. Rich |
blitZ |
Oct 30 2008, 12:25 PM
What size wire did you use? Did you run four new wires??? I understand the relay wiring using the stock setup...got that. Rich I didn't use the 100w H4s, I used the 65w, so I just used the stock wiring. There is no need for relays or extra wiring. However, if you use the 100w bulbs, it seems one wire from the battery to handle 200w would require 10ga wiring. |
Lo-Fi Version | Time is now: 21st September 2024 - 10:07 PM |
