1FASTVW |
Newbie ![]() Group: Members Posts: 12 Joined: 2-July 08 From: North Central Washington Member No.: 9,240 Region Association: Pacific Northwest ![]() |
I have had this car for about 18 years. I drove it for 3 years then put it in storage for the last 15 or so. I started tearing into it about 4 months ago to do a resto/mod, but just don't have the time. What I have done so far could have been done in a couple of weeks. The motor and trans are out, and the motor partly disassembled so I could get a look at the cylinders. They still have the cross hatching in them and no ring groove. Should just need a new ring kit and bearings. It has dual 40mm DellOrtos some unknowing soul put on before I got it. From the records I have tracked, I am the 3rd owner. Newer stainless heat exchangers and all five 2.0 Fuchs wheels are all there. Everything that was taken off the car was tagged and bagged for identification purposes, so finding everything will not be a problem. I have pulled the interior, minus the dash, and there is very minor surface rust. I have stripped much of it to check for any repair panels I might need, but it does not need any. There is a small strip of rust through in the firewall behind the passenger seat that can be repaired without a special panel. The hell hole is non existent on this vehicle. The battery tray is gone, but there is no rust through in the hell hole area. The engine tray on the passenger tray will need to be replaced, but that is it in the engine compartment. The longs are solid. The only area of concern is where the sail panel meets the fender area. These need work, and I have already started on the passenger side. The car is very solid overall, and would make a great project for someone with more time. I have a ton of pictures, as I have been taking them as I go, I can send them to those that are interested. The car will need to be trailered obviously, and all of the smaller parts are in bins, so loading will be easy. I am asking $3500 obo, and if there are any questions, please let me know. Thanks for looking.
Lo-Fi Version | Time is now: 25th June 2024 - 06:38 PM |
