turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
After many repairs, my car finally made it on its first long voyage. The drive was over 2 hours long, and the car did great. However, when i first got my car it would not start after you turned it off. First repair was a new battery, fixed it for awhile, then the fuel pump went. Fixed that with some new wires, and the old fuel pump works perfectly. Car still doesn't start, found out the battery i got was bad, got a new one, and the car starts to run again. After this i take it out and have to have it towed home because the alternator wire broke off the starter, replaced that and the car starts up. At this point everything is running perfectly, so i took the car out yesterday for the long drive that was over 2 hours, get home and my mom parked right in the middle of our driveway, so i can't get the car into the garage. Go in to get the keys for her car and move the thing(don't understand why you park in the middle of a freakin' driveway, but thats besides the point).
I move her car, and get back into the 914 which won't start. I can turn the key and here the starter cranking the engine but it won't fire. Every now and then while trying to start the car it would give a little hint it was about to start but would not turn over. Finally, i decide to let the car sit for awhile while i go vote and run to the atm. The car sat for maybe an hour or two. Get back try to start the car again and it does the same thing, starter cranks and it would hint at starting. I waited for one of the little hiccups the engine would do, like it wanted to start, when it did that i gave it some gas and it turned over for just a little bit. After this, i try to start it again and it fires right up like nothing was wrong. Whats going on? The engine is a 1.8L single carbed engine. Could i be running the car to lean or rich and it just won't fire after a long drive? Thanks everybody. I just want to be able to drive my car, shut it off, and not worry about it not turning on again!!! |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
90% of carb problems are electrical. A couple of things to check. As others have mentioned. ALL Grounds. Old cars that sit will corrode the cables inside the sheathing causing a weak transfer. When the engine is hot, the electrical draw is extreme. This will result in weak spark with a hot engine. If your main pos and neg cables are original and your car sat for many years, I'd start there. Then the main braided cable on the tail housing. Even connected, these corrode and loose connection.
Then you stated you changed coil. Be sure you installed the correct coil. It makes a difference. Check to see your not frying your points. An incorrect coil will cause this. Once you have tested and changed the grounds and the coil, take the car for a long drive. If you have a starting issue, check the spark. Pull the plugs to see if there fouled or fried from running leak. I had a recent issue. I went to the car wash to clean my engine. I had a no start caused by a wet cap. I tried to dry the thing with no joy. I ended up pulling the coil wire out of the cap and leaving lay on the top of the distributor. It arched all over the place and actually started the car. I pushed the wire back on with the engine running and drove home. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 27th June 2024 - 07:06 PM |
