McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I was looking for information on the stock T4 oil pump and couldn't find anything helpful. So I disassembled on of mine today and took some comparison pictures.
Here is the stock pump: ![]() ![]() Once you remove the four nuts on the back, you can use a 6mm x 1.0 bolt and a U shaped piece of steel to pull the guts: ![]() In order to 'blueprint' this oil pump you would need to pull the four little studs, a small alignment ring, and then carefully mill the inside face of the body, thereby tightening the clearances between the flat sides of the gears and the body. Schadek and Melling pumps are much easier to 'blueprint' because you can simply deck the face using something as simple as sandpaper on glass. The stock pump does match up with the oiling bores in the case much better. Here is a stock pump. If you look closely, you can see the small variance: the case hole is slightly smaller than the pump hole. ![]() Here is the Schadek pump body. Notice the much larger variance. ![]() Finally, here are the numbers. ![]() Body Height Measurement: ![]() Total Height Measurement: ![]() And finally, I'm not making any recommendations or judgements about anything here. This thread is simply about posting facts. (IMG:style_emoticons/default/biggrin.gif) |
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
You can't full flow the stock pump as far as I can see.
Dave |
Lo-Fi Version | Time is now: 26th June 2024 - 07:03 AM |
