> T4 Oil Pump Comparisons, Stock . Schadek . Melling
McMark
post Nov 8 2008, 09:33 PM
914 Freak!
I was looking for information on the stock T4 oil pump and couldn't find anything helpful. So I disassembled on of mine today and took some comparison pictures.
Here is the stock pump:
Once you remove the four nuts on the back, you can use a 6mm x 1.0 bolt and a U shaped piece of steel to pull the guts:
In order to 'blueprint' this oil pump you would need to pull the four little studs, a small alignment ring, and then carefully mill the inside face of the body, thereby tightening the clearances between the flat sides of the gears and the body.
Schadek and Melling pumps are much easier to 'blueprint' because you can simply deck the face using something as simple as sandpaper on glass.
The stock pump does match up with the oiling bores in the case much better. Here is a stock pump. If you look closely, you can see the small variance: the case hole is slightly smaller than the pump hole.
Here is the Schadek pump body. Notice the much larger variance.
Finally, here are the numbers.
Body Height Measurement:Attached Image
Total Height Measurement:Attached Image
And finally, I'm not making any recommendations or judgements about anything here. This thread is simply about posting facts. (IMG:style_emoticons/default/biggrin.gif)
Jake Raby
post Nov 9 2008, 10:47 AM
Engine Surgeon
The pumps I have seen need to have the shaft that drives the pump off of the cam pressed into the gear a little farther, so there are plenty of places to screw up.
Unless you purchase the modified TI pump from The Type 4 Store. We mod the pumps before shipping and offer full flow and non full flow versions.
The stock TIV pump can lead to engine failure when the lower pin inside the pump works loose and contacts the camshaft gear. This is the major reason why I haven't used a single stock oil pump in over 15 years.
McMark   T4 Oil Pump Comparisons   Nov 8 2008, 09:33 PM
DNHunt   You can't full flow the stock pump as far as I...   Nov 9 2008, 07:43 AM
davep   Exactly how do you define "full flow"?   Nov 9 2008, 08:05 AM
Joe Ricard   Why would you want too. Normally you full flow so ...   Nov 9 2008, 08:21 AM
DNHunt   All of the oil goes through the filter. With the s...   Nov 9 2008, 08:37 AM
type47   where is/what is/ expand discussion on "small...   Nov 9 2008, 09:26 AM
McMark   where is/what is/ expand discussion on "smal...   Nov 9 2008, 09:02 PM
Jake Raby   Unless you purchase the modified TI pump from Th...   Nov 9 2008, 10:47 AM
DNHunt   Yep, I'm aware of that. Just pointing out t...   Nov 9 2008, 12:41 PM
Joe Ricard   Friends don't let friends drive stock.   Nov 9 2008, 02:51 PM
Mark Henry   A full flow cover and modified engine mount. http:...   Nov 9 2008, 06:17 PM
Mark Henry   A full flow cover and modified engine mount. http...   Feb 12 2021, 11:05 AM
McMark   Yeah, the stocker is not the choice to make for a ...   Nov 9 2008, 08:48 PM
Jake Raby   Lose an engine with 250 miles on it because of a s...   Nov 9 2008, 08:53 PM
jhadler   So... Does anyone sell a full flow modified motor...   Nov 17 2008, 12:52 PM
Mark Henry   I did sell them (as in above pic), look on the l...   Nov 18 2008, 05:24 AM
stevegm   Before I order an oil pump, I just wanted to bounc...   Sep 30 2016, 06:55 AM
Mark Henry   It seems that the consensus is that the Schadek ...   Oct 1 2016, 10:14 AM
stevegm   [quote name='stevegm' post='2405135' date='Sep 30...   Oct 17 2016, 11:53 AM
SirAndy   Holy thread necro! 8 years ... :blink:   Sep 30 2016, 11:21 AM
Valy   I recommend getting an aluminum body type 1 pump, ...   Sep 30 2016, 04:18 PM
McMark   I can still get the 26mm. You gonna modify it you...   Oct 17 2016, 12:00 PM
stevegm   I can still get the 26mm. You gonna modify it yo...   Oct 17 2016, 12:38 PM
KeithVonLaws   Anyone know about these Claudes 26mm pumps? My We...   Oct 18 2016, 02:17 AM
Mark Henry   Anyone know about these Claudes 26mm pumps? My W...   Oct 18 2016, 07:30 AM
KeithVonLaws   Yes Ive seen these pumps for sale before and it is...   Oct 18 2016, 08:56 PM
Shivers   Just when you thought this thread was dead. Puttin...   Feb 12 2021, 09:37 AM
Highland   So perhaps off topic, apologies; but is there any ...   Feb 12 2021, 10:48 AM
peteyd   So perhaps off topic, apologies; but is there any...   Feb 12 2021, 11:47 AM
Montreal914   I will be using a 30mm Shadek pump and a Gene Berg...   Feb 12 2021, 11:23 AM
914Sixer   Tabari did my rockers. He also sells 10mm German ...   Feb 12 2021, 02:21 PM
Mark Henry   $330 is a lot of bones for a pump I'd do...   Feb 12 2021, 03:25 PM
Shivers   Thank you.   Feb 12 2021, 04:47 PM
barefoot   I'm using the CB Maxi Pump 914/type 4 I did li...   Feb 12 2021, 06:14 PM
930cabman   I'm using the CB Maxi Pump 914/type 4 I did l...   Jul 14 2021, 12:16 PM
Shivers   I'm in the Sonoran Desert, gets really hot her...   Feb 12 2021, 08:03 PM
21 User(s) are reading this topic (21 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 14th January 2025 - 09:38 AM
