T4 Oil Pump Comparisons, Stock . Schadek . Melling |
McMark |
Nov 8 2008, 09:33 PM
I was looking for information on the stock T4 oil pump and couldn't find anything helpful. So I disassembled on of mine today and took some comparison pictures.
Here is the stock pump: Once you remove the four nuts on the back, you can use a 6mm x 1.0 bolt and a U shaped piece of steel to pull the guts: In order to 'blueprint' this oil pump you would need to pull the four little studs, a small alignment ring, and then carefully mill the inside face of the body, thereby tightening the clearances between the flat sides of the gears and the body. Schadek and Melling pumps are much easier to 'blueprint' because you can simply deck the face using something as simple as sandpaper on glass. The stock pump does match up with the oiling bores in the case much better. Here is a stock pump. If you look closely, you can see the small variance: the case hole is slightly smaller than the pump hole. Here is the Schadek pump body. Notice the much larger variance. Finally, here are the numbers. Body Height Measurement: Total Height Measurement: And finally, I'm not making any recommendations or judgements about anything here. This thread is simply about posting facts. (IMG:style_emoticons/default/biggrin.gif) |
McMark |
Nov 9 2008, 08:48 PM
Yeah, the stocker is not the choice to make for a full flow setup. But not every engine needs to be full flow.
Lo-Fi Version | Time is now: 27th September 2024 - 01:10 PM |
