LarryR |
Senior Member ![]() ![]() ![]() Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 ![]() |
I was trying to get the trailing arms off today in order to do my 5 lug / brake upgrade. I figured I would use the arms off of the 'outside car' since I already had the rear shocks /springs off of it. So I procrastinated until about 1 thinking it would only be about a 1 hour job HA!! All of the bolts holding the arms on were no big deal. However, the axle nut was a B(&^%$#.
I tried everything. Impact gun for about 15 minutes, then ratchet, then cheater bar on ratchet, then brake handle on ratchet and snap I broke my craftsman 1/2 drive. (yes I know I should have started with a breaker bar just to lazy to walk bak in the garage and get it). All the while spraying it with liquid wrench between attempts. So I go dig out the breaker bar and another 10 minutes of grunting with 5' of leverage and the little bastard finally let go and of course I smash my thumb when it does. I have never seen an axle nut on so freakin tight. Since I know it will be dark in another 1/2 hour the other arm will have to wait till next weekend(now I know to start early). At least I can get started on 1 of them this week. Now its (IMG:style_emoticons/default/beer3.gif) time |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
I think you'll be filling that grinder case up with hot water for a foot soak after tonight! (IMG:style_emoticons/default/biggrin.gif)
LarryR |
I think you'll be filling that grinder case up with hot water for a foot soak after tonight! (IMG:style_emoticons/default/biggrin.gif) Hey Eric, I guess you can see from the progress its going to be another week before I sent it all off to you. I forgot to ask on the A Arms do you want me to cut the old sway bar mount off? Larry |
Lo-Fi Version | Time is now: 25th June 2024 - 08:01 PM |
