byndbad914 |
shoehorn and some butter - it fits ![]() ![]() ![]() Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None ![]() |
Here is what they posted regarding an issue I mentioned with their junk 2 yrs ago in the track car pix area.
The following is a copy of a PM sent to this poster.... It aggravates me when a single person posts unwarranted comments. As I stated in my PM ....let's see some pictures. After viewing a post that you made, I would like to respond to your accusations of our 935 control arm breaking. A review of our records show no sale of a 935 system shipped to you. If in fact if you did purchase one of our systems, you would have our telephone number which you obviously never used. Every single 935 system is check on an actual chassis for fitment prior to shipment, so your claim of it not fitting leads me to believe this is classic case of not following directions. There are over 40 of our 935 systems installed and in use, and not one, to my knowledge has failed due to material or fabrication. I fail to see any pictures of this supposed failure anywhere on the 914 world site, which leads me to wonder if you in fact did some "backyard" engineering and don't want anyone to see the facts, and just point the finger at us. I stand behind every item that I make, if there is a problem it would have been corrected if you had put as much effort in picking up a phone as you do slandering people. Wanted to get a shot at Willow Springs before leaving for Colorado, but the new 935-style lower arms I bought from Kanna Motorsports snapped in two with only 1/3 of a lap down when I went out last month (IMG:style_emoticons/default/mad.gif) That 30 seconds of track time cost me about a grand and, of course, Kanna won't respond to my email asking them WTF they would like to do about it. Don't buy Kanna Motorsports stuff PERIOD. A couple other items I got required additional machining as well to make them right btw. But here it is when I picked it up at the chassis shop. (I snipped all the pix of the car to save space here) and here was my reply to them, just so everyone knows exactly what is going on. Additionally, as many of you already know about my car, it was professionally built and is in no way a "backyard" car. took me awhile to find the thread they were talking about having my post. I will quote my response: QUOTE First and foremost this happened 2 yrs ago, so it's been a loooonnnngggg time ago. Secondly, I called a number of times after it happened, left messages and even emailed you jackasses. Thirdly, and more importantly, you sold me the lower control arm piece only (and some upper strut mounts which also needed to be remachined BTW), but it was a "custom" piece you had made for someone else, then they apparently didn't take it and you offered it to me. It was custom because you had made an adjustable sleeve so that you didn't have to unbolt the arm to adjust camber. That sleeve piece that was made had a 3/4" outside thread and a 5/8" inside thread.. which means there was less than 1/8" of material holding that arm together in tension and I didn't catch that when the car was built. As I entered turn 5 at Willow Springs, on the first lap, maiden voyage of the car that custom piece you had made tensile failed, snapped in half, causing the front tire to be shoved back into my car, destroying a brand new Hoosier, busting my fiberglass rocker bodywork, etc. That was a $1000 day for me between new tire, track fees, round trip gas for 30 seconds of track time, and damage to my car. Don't you fucking dare fire at me after 2yrs of hearing nothing from you - after waiting to hear from you for quite awhile and hearing nothing I made that post to let others know to stay away. This failure happened in December of 2006! I left no less than five phone message, and fired a couple emails as well. It was not installed improperly or any thing like that. In fact, if I search around my garage I think I still have the failed part and I would have been happy to take a photo to show you but your attitude right out of the hole is BS and I am thru with you. Or you can cut me a check for $1000 and we will call it even. In addition after thinking about this a bit and stewing even more (trust me, this was the worst track day of my life to date and a reeeeaaaaal sore spot) I should point out the camber/caster upper strut mounts were shit as well. There are four bolts that hold the two pieces together - one of them was drilled far enough off center you couldn't get the fourth bolt in - they did of course and the threads had clearly dug into the aluminum part while they forced it in place. AJ just ended up hacking that part a bit, supporting it with the frame and to this day I just run 3 bolts as everything is now in compression and shear friction. After AJ cut the arm to reset the length and we removed his shit ass adjuster piece, I haven't had a single issue with the arm. I suspect if you only use their non-sleeved, single adjustable part you may not have any issues, as that is essentially what I have now. I should have known better than to take custom pieces that were refused by a previous customer. Just understand their level of craftsmanship is faaaarrrrr and away more backyard than anything on my car. At the time I purchased these parts I had more money than time and didn't care to machine them myself when I could just buy them for a good price (I have long since moved on from machining parts when I became a professional engineer). However, I got what I paid for apparently. Since it has been 2 yrs I may or may not still have that shit piece in my garage and will look around for it and post a pic of that POS so everyone on this forum can see what a POS that part was. Had this prick answered no less than 5 voicemails including one I left driving home after spending 3hrs on the track trying to get this car on the trailer, and a couple emails I also sent, this would have never happened and would not have been public. There is your Kanna customer service... ship you crap shit, you can leave them a bunch of messages, etc, after it fails immediately, then wait 2 yrs so you might not have the offending part (I have moved twice since including a new state so probably why he can't figure out the order which is almost 3 yrs ago now), come from outta nowhere... again, wait for it.... AFTER 2 YEARS... and accuse you of never having ordered or used their parts, blah blah. You may have wanted to send me a more polite, inquisitive email before going public jackass - you only dig yourself a deeper hole. I will take some pix of the shit upper pieces and the raw alum showing in the slots where we had to go in and make clearance so the threaded fasteners would actually slide in the slots. I essentially rely on the lower arms for all of my caster and most of my camber adjustments after having to just hard mount your shit pieces. You have managed to get me boiling about something I have tried to forget for 2 fricken years now. |
byndbad914 |
don't have to be an engineer to know you shouldn't thread the outside 3/4" RH and the inside 5/8" LH!!! I did the math back when it broke and IIRC there was literally only .030"-.050" thick sections with high stress concentrations from cut threads holding the whole lower arm together!
Just because you can use a machine makes you a machinist, not an engineer, nor for that matter prove any sort of common sense. I can't believe I didn't catch this when I adjusted the suspension the first time... I sorta recall thinking looks kinda spindly but again, "they do this kind of stuff all the time" in the same sentence they refer to this as a custom piece. Look how thin!!!! Keep in mind, the rod end has 5/8" diam threads!!!!!! for comparison. I literally shit myself when I saw the failure and saw how thin. ![]() |
Lo-Fi Version | Time is now: 19th April 2025 - 08:22 AM |
