jc914 |
Member ![]() ![]() Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States ![]() |
I just finished cleaning all the inside glass of all my gauges (what a difference they look NEW) So I toke her out in the Miami weather tonight the outside temp was a nice hot 80 degrees. I drove my 914 for over an Hour an Half I drove her really hard and fast up 80MPH:driving: . The OEM temp gauge only read a 1/4 up and it never even got half way up (IMG:style_emoticons/default/piratenanner.gif) . Once I got home I opened the engine lid and the Dip stick Temp Gauge read 250 degrees. ( note i have checked the dip stick boiling point yesturday before i installed it.) If My 914 is running hot what what might be the causes and which gauge should i trust. (IMG:style_emoticons/default/devil.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
The car idled at 1 the whole night when i got home i turned her of and then on again after like 5 minutes and it started with some gas on the peddle. thanks JC |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
For those who are wondering what a dip stick gauge is, I'll throw out a free plug for the vendor as he is a good one...
http://www.mainelycustombydesign.com/engin...s.html#dipstick Also it reads temp right where the stock sender does, (if' you've ever had the temp sender plate off you can see the bottom of the dipstick) so the temp readings are taken from the same location. I used the dipstick gauge to give me real time readings from the stock gauge in the car... After a few drives and stopping to check the dipstick gauge, you can see where the stock gauge is, and get a idea of what the non numbered gauge is telling you. One warning though, it will make you nervous, as I could not believe how hot "normal" was on the stock gauge. Straight up and down, on the gauge with the small red zone is right about 215, if the needle is touching the "M" on the word TEMP you are 235-240ish and if you are on the P it's 250 and above, all below the red zone. Ferg |
Lo-Fi Version | Time is now: 28th June 2024 - 11:22 PM |
