My MicroSquirt Install |
McMark |
Jul 20 2008, 05:00 PM
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate. Anyway, now on the the fun stuff! I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today. Attached image(s) |
CliffBraun |
Nov 14 2008, 12:48 AM
Member Group: Members Posts: 252 Joined: 26-April 06 From: San Luis Obispo,ca Member No.: 5,933 Region Association: None |
Re MS and going distributorless, there is apparently some board in development that would let you fire up to 8 injectors and plugs on their own. In my mind this becomes a very efficient, very nifty coil on plug system. The injector thing is cool, but you're really only getting benefit at low RPM (primarily low temp, even) because your injectors are open longer than the valves at the top end.
Anywho, I would have linked the page but I couldn't find it. Does anybody know any more about this than I? |
banger |
Nov 14 2008, 11:37 AM
Member Group: Members Posts: 354 Joined: 12-November 06 From: Santa Clarita Member No.: 7,205 Region Association: Southern California |
Actually you can do coil on plug quite easily with the megasquirt. You dont need the extra board either. You can take the Ford EDIS module, and instead of having it run coilpacks, it can be wired to run coil on plug. It is still running a wasted spar system, but instead of having 1 coil fire 2 plugs, now you have 2 coils firing 2 plugs.
Re MS and going distributorless, there is apparently some board in development that would let you fire up to 8 injectors and plugs on their own. In my mind this becomes a very efficient, very nifty coil on plug system. The injector thing is cool, but you're really only getting benefit at low RPM (primarily low temp, even) because your injectors are open longer than the valves at the top end. Anywho, I would have linked the page but I couldn't find it. Does anybody know any more about this than I? |
CliffBraun |
Nov 14 2008, 03:50 PM
Actually you can do coil on plug quite easily with the megasquirt. You dont need the extra board either. You can take the Ford EDIS module, and instead of having it run coilpacks, it can be wired to run coil on plug. It is still running a wasted spar system, but instead of having 1 coil fire 2 plugs, now you have 2 coils firing 2 plugs. Re MS and going distributorless, there is apparently some board in development that would let you fire up to 8 injectors and plugs on their own. In my mind this becomes a very efficient, very nifty coil on plug system. The injector thing is cool, but you're really only getting benefit at low RPM (primarily low temp, even) because your injectors are open longer than the valves at the top end. Anywho, I would have linked the page but I couldn't find it. Does anybody know any more about this than I? I'm aware of this, I just don't like the idea of wasted spark (IMG:style_emoticons/default/smile.gif) . Not that that is really rational. I like the idea of per cylinder control, though. Still havn't managed to find the page on the other board. Hm, on further thought with just a crank sensor you kinda have to run wasted spark, I remember MS having another method of picking up where you are in your cycle though, have to go figure that out later. |
Lo-Fi Version | Time is now: 28th September 2024 - 12:54 PM |
