McMark |
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate. Anyway, now on the the fun stuff! I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today. Attached image(s) ![]() ![]() |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
what is the compatibility between MS and the type of camshaft? is MS sensitive to agressive cams like D-jet? the reason i ask is my "next" motor is to be a 96mm digital FI motor but i have a "race" motor on the floor that had carbs. i don't remember the specs on the cam, i have the build sheet, but i'd bet it was a carb cam. so my question is (to save me from building a motor up from the crank), can i install MS on this "race" motor?
MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 07:10 PM |
