> Rear Reflector and Trunk Release
STL914
post Jan 16 2004, 11:45 PM
I'm considering installing a rear PORSCHE reflector on my '72 and need some advice/opinions on what type of trunk release to use. I know that most use the electric soleniod but I have also read of people using some type of cable set up. Can someone tell me more on the cable method with some photos?
Thanks (IMG:style_emoticons/default/smilie_flagge6.gif)
boxstr
post Jan 17 2004, 11:00 AM
Gary Good morning. I own 2 914s with rear reflectors. If you really have a pristine car(914) then I personally would not cut,drill,or add anything that was not factory. You can always do that to a project type car. Or one that comes your way(they always do) that you may feel needs to rear reflector.
Six holes I believe they are @12mm, haver to be drilled for the mounting studs. The electric solenoid is what is supplied, but it needs a backup, as others have stated, a cable is the best way to go. The one straight down and behind the rear lic. plate is easy and works great.
CCLINREFLECTORHELL
STL914   Rear Reflector and Trunk Release   Jan 16 2004, 11:45 PM
campbellcj   The solenoids are pretty reliable but I think it i...   Jan 16 2004, 11:50 PM
Brad Roberts   Hi Gary, I need to dig up the pics to show you.....   Jan 16 2004, 11:54 PM
SirAndy   yupp, what they ^^^^ said. i have a "solenoid" fo...   Jan 16 2004, 11:59 PM
SirAndy   not the best of pics (surprised?), but it'll g...   Jan 17 2004, 12:00 AM
bernbomb914   I have the selonid but I drilled a small hole unde...   Jan 17 2004, 12:02 AM
campbellcj   I just took the reflector and "GT" tail off my car...   Jan 17 2004, 01:29 AM
John2kx   I was up against the same question after installin...   Jan 17 2004, 06:45 AM
Van914   My car came with the rear reflector when I bought ...   Jan 17 2004, 07:25 AM
STL914   Thanks for the replies guys. I bought a cut done 9...   Jan 17 2004, 10:02 AM
Neal   How is the solenoid wired I just got the system an...   Jan 17 2004, 10:43 AM
boxstr   Gary Good morning. I own 2 914s with rear reflecto...   Jan 17 2004, 11:00 AM
Air_Cooled_Nut   I installed a cable-released PORSCHE reflector in ...   Jan 17 2004, 11:51 AM
Neal   has anyone ever thought of putting lights behind t...   Jan 17 2004, 08:38 PM
Kargeek   At one time I had the cut down 911 reflector on my...   Jan 17 2004, 09:05 PM
soloracer   Could a trunk latch like this be used with the ref...   Jan 17 2004, 09:52 PM
Air_Cooled_Nut   <...   Jan 17 2004, 10:18 PM
Kargeek   I also used a thinner tape to fasten the VW-Porsch...   Jan 17 2004, 11:00 PM
Brad Roberts   I have a customers car that kept the stock lock in...   Jan 17 2004, 11:05 PM
Neal   I am so doing the tape and leaving the lock on, I ...   Jan 17 2004, 11:46 PM
STL914   Neal, You asked "has anyone ever thought of putti...   Jan 18 2004, 03:42 PM
Neal   I held mine up to a light and you can see through ...   Jan 18 2004, 11:29 PM
Engman   I have one on mine. I did not drill the holes to m...   Jan 19 2004, 07:48 AM
STL914
  Jan 19 2004, 11:59 AM
hargray2   you can get velcro in almost any size you want. If...   Jan 19 2004, 06:37 PM
Engman   Six one inch strips - nope never lost it and there...   Jan 19 2004, 07:55 PM
Neal   Engman, can you take a picture of you refabbed arm...   Jan 20 2004, 09:04 AM
Engman   In my best Dr. Evil voice - "I used a Laser". Ma...   Jan 20 2004, 12:09 PM
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 09:19 PM
