New Radiator Hose Routing Inside Body SOLVED!, Check out this route through all existing tunnels! |
budman5201 |
Nov 15 2008, 06:26 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
I was cutting up a parts car and found 2 hidden tunnels all the way to the front trunk on either side of the gastank underneath it basically where the hidden bottom bolt for the swaybar attachment is hiding.
So from front trunk location, through tunnels found, inside cab 1.5 feet around wheelwells, through heater tunnels in longs, to rear!! This is the route i am using and I am using 1.5 ID bellowsflex so no kinking at all is possible! Subaru Clean conversion on the way! I will mock up some removable panels to cover up the exposed 1.5 feet of cable that run through the hidden tunnels to connect to the heater tunnels...... This route will eliminate any bubbles in radiator hose due to not running it up high!! |
So.Cal.914 |
Nov 15 2008, 06:32 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
One of the V8 guys ran his hoses in a simular way. I think it was Drivability(sp?).
Lo-Fi Version | Time is now: 28th September 2024 - 05:55 PM |
