budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
I was cutting up a parts car and found 2 hidden tunnels all the way to the front trunk on either side of the gastank underneath it basically where the hidden bottom bolt for the swaybar attachment is hiding.
So from front trunk location, through tunnels found, inside cab 1.5 feet around wheelwells, through heater tunnels in longs, to rear!! This is the route i am using and I am using 1.5 ID bellowsflex so no kinking at all is possible! Subaru Clean conversion on the way! I will mock up some removable panels to cover up the exposed 1.5 feet of cable that run through the hidden tunnels to connect to the heater tunnels...... This route will eliminate any bubbles in radiator hose due to not running it up high!! |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
that hump in the footwell is structural. it is the support that ties teh "A" pillar, long box and front suspension together
Lo-Fi Version | Time is now: 29th June 2024 - 04:17 AM |
