What oil temp Temperature gauge do I trust, Just installed the new Pressure & CHT guages |
jc914 |
Nov 13 2008, 09:00 PM
Member Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States |
I just finished cleaning all the inside glass of all my gauges (what a difference they look NEW) So I toke her out in the Miami weather tonight the outside temp was a nice hot 80 degrees. I drove my 914 for over an Hour an Half I drove her really hard and fast up 80MPH:driving: . The OEM temp gauge only read a 1/4 up and it never even got half way up (IMG:style_emoticons/default/piratenanner.gif) . Once I got home I opened the engine lid and the Dip stick Temp Gauge read 250 degrees. ( note i have checked the dip stick boiling point yesturday before i installed it.) If My 914 is running hot what what might be the causes and which gauge should i trust. (IMG:style_emoticons/default/devil.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
The car idled at 1 the whole night when i got home i turned her of and then on again after like 5 minutes and it started with some gas on the peddle. thanks JC |
Ferg |
Nov 16 2008, 08:05 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Flaps are supposed to fail in the "safe" mode, but it's always best to verify... grab the tab where the wire connects and move them by hand and make sure they are not binding or stuck.
Do you have emissions in FL? If so did you pass easy and what were your readouts. Ferg |
Lo-Fi Version | Time is now: 28th September 2024 - 04:43 PM |
