My MicroSquirt Install |
McMark |
Jul 20 2008, 05:00 PM
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate. Anyway, now on the the fun stuff! I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today. Attached image(s) |
McMark |
Jul 24 2008, 07:53 PM
Here's the picture of the AMPSEAL connector. You can see the red seal around the perimeter.
RJMII |
Nov 13 2008, 12:13 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Here's the picture of the AMPSEAL connector. You can see the red seal around the perimeter. Where does that connector go? is that the one that attaches to the MS? I've been looking for a pair of connectors (male/female set) for quick disconnect between my engine harness and the body harness. (Then again, I might just go with a handful of smaller connectors... hmm..) |
smdubovsky |
Nov 13 2008, 01:05 PM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
Where does that connector go? is that the one that attaches to the MS? Yes, that connector goes to the MS. AFAIK, ampseal connectors were difficult to get in small qty. That may have changed. Its not an issue w/ the MS since it comes w/ both halves (plus, Im sure they are ordering them in large qty.) |
kconway |
Nov 13 2008, 02:50 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Where does that connector go? is that the one that attaches to the MS? Yes, that connector goes to the MS. AFAIK, ampseal connectors were difficult to get in small qty. That may have changed. Its not an issue w/ the MS since it comes w/ both halves (plus, Im sure they are ordering them in large qty.) Looks like they can be had here with a min buy of 1 for $16.75 http://www.mouser.com/Search/ProductDetail...WfMWf98IA%3d%3d |
smdubovsky |
Nov 17 2008, 01:21 PM
Looks like they can be had here with a min buy of 1 for $16.75 http://www.mouser.com/Search/ProductDetail...WfMWf98IA%3d%3d Cool. Do be aware the different colors are keyed differently. (A red wont plug into a black.) You have to get both M&F halves of the same color. |
Lo-Fi Version | Time is now: 28th June 2024 - 09:38 AM |
