watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
Last week I swapped out the ignition tumbler then started having electrical problems. I decided this weekend I would try to tackle them. BTW, I have a '74 2.0l FI. Here's the situation:
When I turn the ignition switch on, I don't get any power to the fuse panel nor the fuel pump nor the starter. Before swapping the tumbler, everything was working fine, except the headlights wouldn't raise. They would light up, but not pop up. So, I checked the wiring diagram. Here's my interpretation of the ignition switch..... 30 - power from the battery (red) X - headlight switch (red) 15 - fuse #9 (black) & seat belt warning light (red) P - starter S - seat belt warning w/buzzer(gray/brow) 50 - seat belt warning w/buzzer (yellow) I pulled the tumbler and checked for power at ignition plug #30 - good - 12v When I turn the key, I get power to fuse #9 (12v). Also the seat belt warning light comes on (the one in the dash above the vent controls). When I close the doors, the light doesn't lite up. The seat belt buzzer sounds, but stops when the doors are closed. Looking at the diagram, it appears that there should be power to the red wire at fuse #11. I checked and nothing. I decided to place a wire directly from the battery to the #11 fuse. When I installed this wire, my headlights raised and lit up. The fog lights worked. The windshield wipers worked. The turn signals worked. Is there suppose to be a direct connection between the battery and the fuse panel? And if so, where is the conection? I think the ignition switch is bad, but I swapped out (2) others that I have in my stash, but they didn't work either. Joe has suggested that I remove the ignition switch from the tumbler and use a small screwdriver to turn the switch, which I'll perform tomorrow. Any suggestion? BTW, I don't have internet connection at the shop, so I won't be able to check until tomorrow. -- Rob |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The seat belt relay assembly does something with the starter signal to the starter. Power from one of the F10-F12 fuse goes to this assembly. If power is not on the fuses, then the starter will not start.
About the FI fuel pump, do you hear the 2 second startup when you put the key in the RUN position? My guess is that the "no power to fuses 10-12" is causing all your problems. Question: What was happening with your car before you changed the ignition switch? What wasn't working before you changed the ignition switch? |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Question: What was happening with your car before you changed the ignition switch? What wasn't working before you changed the ignition switch? [/quote] His fingers were under the dash. (IMG:style_emoticons/default/poke.gif) |
DM71SIX |
Newbie ![]() Group: Members Posts: 18 Joined: 30-September 05 From: CUYAHOGA FALLS, OHIO Member No.: 4,893 ![]() |
[font=Arial][size=7][quote name='Joe Ricard' date='Nov 18 2008, 01:43 PM' post='1103131']
Question: What was happening with your car before you changed the ignition switch? What wasn't working before you changed the ignition switch? [/quote] His fingers were under the dash. (IMG:style_emoticons/default/poke.gif) [/quote] I need the wireing pattern for a 914-6 ignition switch. When I put a new electrical part on the wires popped off! I am not sure I got tham back on correctly. Any sugestions? |
Lo-Fi Version | Time is now: 24th June 2024 - 11:35 PM |
