Dang this time the arm won big time |
LarryR |
Nov 16 2008, 06:47 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
Trying to get the axle nut off the drivers side was even worse! I was lifting the car off the ground with 8' of leverage and the little b*#& would not move. That must have been close to 1000# of pressure to lift the car. it even snapped the bolt that was in the middle of my jack handle... I am worn out but I guess the next manuver will be to have a couple friends over to sit in the trunk while I go for it... I soaked it 5x throughout the week with liquid wrench... thats one tough nut!
If that doesnt do it I guess I will just cut it off. Since I dont need the axle stubs that actually might be easier. I have taken axles out of many 911's and never had anything close to this amount of grief. |
zambezi |
Nov 20 2008, 01:26 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
I am surprised no one has mentioned the torque multiplier that bolts to the rotor. I have never tried one on a teener yet but have used it on 356's and vw's. The multiplier has the bolt spacing for VW wide 5 and VW 4 lug. The bolt pattern for 5 lug porsche is on the same circle as the 4 lug so an adapter plate could be made to make it work for the 5 lug cars. Using the multiplier it should only take about 40-50 ft./lbs of torque to remove and install the axle nut. I'll have to look at mine and see about making an adapter plate to see if it would work but I can't see why not if it will work on a 4 lug bug.
Heres a link to the tool I'm talking about: http://www2.cip1.com/ProductDetails.asp?Pr...CC%2DC10%2D7036 |
Lo-Fi Version | Time is now: 24th September 2024 - 01:01 PM |
