Dang this time the arm won big time |
LarryR |
Nov 16 2008, 06:47 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
Trying to get the axle nut off the drivers side was even worse! I was lifting the car off the ground with 8' of leverage and the little b*#& would not move. That must have been close to 1000# of pressure to lift the car. it even snapped the bolt that was in the middle of my jack handle... I am worn out but I guess the next manuver will be to have a couple friends over to sit in the trunk while I go for it... I soaked it 5x throughout the week with liquid wrench... thats one tough nut!
If that doesnt do it I guess I will just cut it off. Since I dont need the axle stubs that actually might be easier. I have taken axles out of many 911's and never had anything close to this amount of grief. |
r_towle |
Nov 20 2008, 10:53 AM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Congrats on getting it off. They can be a bugger sometimes.
Its a VW thing...the beetle axles are the same way but most are at 750 lbs. the 356 axles and the flywheel nut are the same... The 10 foot bar with a 3/4 drive breaker bar all properly supported does the trick in most cases. I bet that most people that have worked on these cars have broken a 1/2 inch drive breaker bar at some point on those same nuts. I never thought I would need a 3/4 drive anything...but alas I now have one. I have broken bars, adapters and sockets on these nuts... Now I am older...I have a dedicated set just for this nut. Rich |
MartyYeoman |
Nov 20 2008, 02:10 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
The 10 foot bar with a 3/4 drive breaker bar all properly supported does the trick in most cases. I bet that most people that have worked on these cars have broken a 1/2 inch drive breaker bar at some point on those same nuts. I never thought I would need a 3/4 drive anything...but alas I now have one. I have broken bars, adapters and sockets on these nuts... Now I am older...I have a dedicated set just for this nut. Rich (IMG:style_emoticons/default/agree.gif) I've done the same!! |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:09 PM |
