jc914 |
Member ![]() ![]() Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States ![]() |
I just finished cleaning all the inside glass of all my gauges (what a difference they look NEW) So I toke her out in the Miami weather tonight the outside temp was a nice hot 80 degrees. I drove my 914 for over an Hour an Half I drove her really hard and fast up 80MPH:driving: . The OEM temp gauge only read a 1/4 up and it never even got half way up (IMG:style_emoticons/default/piratenanner.gif) . Once I got home I opened the engine lid and the Dip stick Temp Gauge read 250 degrees. ( note i have checked the dip stick boiling point yesturday before i installed it.) If My 914 is running hot what what might be the causes and which gauge should i trust. (IMG:style_emoticons/default/devil.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
The car idled at 1 the whole night when i got home i turned her of and then on again after like 5 minutes and it started with some gas on the peddle. thanks JC |
jc914 |
Thanks steve I am going to get Oil pressure and a cht. as for the oil pressure which sender do I get. look at the link below I want a dual sender for the light and the gauge. The differnce is a floating ground or a standard ground. which one do i get.
http://egauges.com/vdo_send.asp?Sender=80PSI_5Bar_VDO Also Steve you have an A/C like I do in the car where did you place the extra 2 gauges in the dash. Once again Thank YOU JC |
Lo-Fi Version | Time is now: 28th June 2024 - 11:44 PM |
