415PB |
Member ![]() ![]() Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 ![]() ![]() |
I finished my rebuild about a month ago. I've driven my teener for only about 20 miles since. I have a small puddle of oil on the garage floor, which I believe is coming from the small window in between the engine and tranny. I drove it today for a couple of miles, parked it in the garage and it immediately began to drip oil from the above location. I checked my oil and it is about an eighth inch to a quarter inch above the full mark. I guess I over filled the oil. I replaced the rear main seal during my rebuild and can't imagine that this is the problem. It is definately oil and not gear oil. How hard would it be to remove just the tranny and not the engine. I don't think I can go through removing the engine again, but I will if I have too. Any suggestions are greatly appreciated.
Thanks, Rod |
415PB |
I'm pretty sure they were small pieces of rubber so I probably wont do much about it then. As for the pivot ball, I did notice that it is leaking. I will take it off and seal it up. Thanks for the help.....
Lo-Fi Version | Time is now: 22nd June 2024 - 07:39 PM |
