What oil temp Temperature gauge do I trust, Just installed the new Pressure & CHT guages |
jc914 |
Nov 13 2008, 09:00 PM
Member Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States |
I just finished cleaning all the inside glass of all my gauges (what a difference they look NEW) So I toke her out in the Miami weather tonight the outside temp was a nice hot 80 degrees. I drove my 914 for over an Hour an Half I drove her really hard and fast up 80MPH:driving: . The OEM temp gauge only read a 1/4 up and it never even got half way up (IMG:style_emoticons/default/piratenanner.gif) . Once I got home I opened the engine lid and the Dip stick Temp Gauge read 250 degrees. ( note i have checked the dip stick boiling point yesturday before i installed it.) If My 914 is running hot what what might be the causes and which gauge should i trust. (IMG:style_emoticons/default/devil.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
The car idled at 1 the whole night when i got home i turned her of and then on again after like 5 minutes and it started with some gas on the peddle. thanks JC |
Gint |
Nov 23 2008, 07:38 PM
Mike Ginter Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
That boot is the cooling vent for the alternator. If it's off, you'll lose some cooling air flow from the rest of the system, so in theory it would affect your oil temps. But I doubt it would be by much. I can't quite tell from that pic, but if it's disconnected you should loosen that clamp and put it back on.
Lo-Fi Version | Time is now: 28th June 2024 - 11:03 PM |
