My 914-6 GT build sheet, your opinions and add ons.... |
futuresoptions |
Nov 23 2008, 01:57 PM
Happy Camper Group: Members Posts: 55 Joined: 14-November 08 From: Tejas Member No.: 9,757 Region Association: None |
Okay, with the help of the board I have been able to come up with a basic build sheet for the car I will be purchasing and starting on... Thanks for all of the input that has gotten me to this point.
I will be taking this list that I have made and will be breaking down into a TO DO list and a PARTS TO BUY list. If you can think of anything that I should add or consider please feel free to chime in.... I feel pretty confident on what is needed for the 6 conversion... and will let PMB guide me when I am ready on the rear brake / 5 lug conversion... Will probably be going with a Rennshift setup... I am considering a Motor Meister 914-6 kit, but I am hesitant as I have heard some negatives about them.. Is there anyone else that may provide this service/kit or should I just find a low mileage 3.2, slap some PMO's on it and purchase parts individually to complete my conversion. PORSCHE 914-6 GT Project Car: 1973-1976 914 Rust free as possible. (Strip her to the Bones) Mechanicals: Install new fuel line and pump, replace all wiring in car, install electric washer pump, install stainless clutch & accelerator cable, petronix ignitor, relocate battery to front trunk(Red top). Engine: 3.2L Twin Carbs, headers, quad tips out rear.. Tranny: Beefed up and rebuilt 901 side shifter. premium upgraded shifter and components to tranny. Paint/Body: Steel GT flares from Automobile Atlanta, front and rear spoilers. Complete paint and body job with premium chassis stiffening kit installed... Suspension Front: Either install 911SC or 930 front suspension, should drop right in. 930 is more expensive, but has larger calipers, drilled rotors and turbo tie rods. 911SC with turbo tie rods would be just fine. Plan replacing any bushings, bearings, and strut inserts. Possible upgrade on sway bar.. Suspension Rear: Contact PMB Performance for the 5-lug conversion/brake information, Beefed up/reuilbt/new trailing arms. Replace springs, bushings, bearings and strut inserts. Install heavy duty cv shafts. Interior: Black-mainly stock.. Wheels/Tires: 16" Black 911 Fuch's 7" in front, 8" rear |
burton73 |
Nov 23 2008, 09:19 PM
burton73 Group: Members Posts: 3,563 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Bill,
The 3.2 with the factory injection is great. You will spend $3,500 or so for the PMO carbs. and manifolds or you can get great performance if you let Steve Wong tune your chip for the 914-6 headers and muffler set up you use. I have a Steve chip in my 86 Carrera 3.2 and my car passes smog in California and I do not run a catalytic converter on it just a Dansk clear pipe. If the people do not see it I am fine. My car has power across the power band with an increase in lower end power all the way up to red line. The Wong chip was the biggest bang for the buck at a $100. When I got it. He programs the chip on his computer. He is close to me so I just drove over to him. Nice guy as well. Smog will not be an issue for you because of the year, but the point is he can tune the injection to do what you need in the chip and it will be great. With headers it should be well over 230 HP as that is what my car is set to put out with stock pipe no headers. This can save you a lot of money. Bob |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:34 PM |
