Why do valves need adjusting?, What's behind it all? |
kpfoten |
Nov 25 2008, 01:22 PM
Member Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None |
I'm a relative newbie when it comes to engine rebuilding, the physics, mechanics, etc, but I'm fascinated by it all and have been reading up on how it all works... I've done my share of valve adjustments, but the thought came to mind--why do we adjust valves? Is it a combination of heat and wear that causes them to need adjusting? Does spring fatigue have something to do with it?? |
kpfoten |
Nov 25 2008, 02:39 PM
Thanks!
I would assume that air cooled motors (even though with valves regularly adjusted) need the heads re-done sooner over time? |
Cap'n Krusty |
Nov 25 2008, 07:36 PM
Thanks! I would assume that air cooled motors (even though with valves regularly adjusted) need the heads re-done sooner over time? Not particularly. BTW, spring fatigue has come up before, and it's not a possible answer, because the valve is a fixed length, the spring retainer is in a fixed location, and any tension at all will cause the valve to be fully closed at rest. Note I said "closed", not "sealed". The Cap'n |
Lo-Fi Version | Time is now: 24th September 2024 - 12:51 PM |
