RiqueMar |
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California ![]() ![]() |
Ok guys! Time for antoher one of my 'dumb rookie' questions.
What brake calipers are applicable to my 914? I don't want to use the originals, and I'm turning it into a GT. Any seperate years or models I can use? Please, endow your knowledge upon me (IMG:style_emoticons/default/pray.gif) |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
My 2 cents for what that's worth (IMG:style_emoticons/default/biggrin.gif) I have a 75 chassis that I'm converting to a /6 with a 911 3.0 engine. I have converted to 911 front struts 3 inch spacing and running M calipers with 20mm thick vented rotors. In the rear I've converted to 911 5 lug with 911 E-brake and M calipers also with 20mm vented rotors.. I am not running a proportioning valve just a tee. Also installed a 19mm master cylinder and all new brakes lines from the master cylinder to the calipers. I fully expect this setup to whoa just fine (IMG:style_emoticons/default/biggrin.gif) This is basically the same setup I have on my 83SC and I have no problems with that heavier car at AX's or DE's. I'm guessing I may have to play around with pads to get good forward/rear bias but I don't think that will be a show stopper. I have 16x7 and 16x8 Fuchs and BBS wheels that I'll probably have 225 + 245 tires so traction should not be an issue. Good luck with whatever you choose to do. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 24th June 2024 - 07:19 AM |
