FS: 1974 914/4 2L Ravenna Green, 5-lug solid chassis in PA |
Spoke |
Nov 28 2008, 01:54 AM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
For Sale:
1974 914/4 2L w/stock FI $7495 obo Features: ********************************************* Ravenna Green with chrome bumpers Stock 4-cylinder 2.0L D-Jetronic Fuel Injected engine Low rust chassis; very solid; longs in great shape Original battery tray w/some surface rust; no rust in hell hole Stainless Steel Heat Exchangers with Bursch exhaust Interior in very good condition Custom flared rear fenders (stock fenders hammered & dollied out) 5-Lug (1987 911) front end; Eric Shea 5-lug converted hubs in rear Front Wheels: 205/50/15 Yokohama ES100 (75%) on 7 inch wide replica fuchs Rear Wheels: 225/50/15 Yokohama ES100 (60%) on 8 inch wide replica fuchs Spare: 195/60/14 on 5.5 inch wide genuine fuch 151,000 Miles Car cover included Details ********************************************* Chassis/Body: Low rust chassis; Longs in great shape Door gaps perfect even when jacked up Surface rust around jack points; no other rust on longs Original battery tray w/some surface rust; no rust in hell hole Original sail panel vinyl with no surface rust/bubbles Rear trunk floor some surface rust recently sandblasted/primed Original valences front/rear Original rocker panels; passenger rocker rust repaired; driver rocker has some rust Cabin Floors in great shape 3 inch of surface rust around driver side bottom of windshield Original rear fenders flared with hammer & dolly to fit 8 inch rims Some surface rust around front body panel behind front bumper (was replaced at one time) Chrome bumpers: front 73+ (bumperette holes), rear pre-73 (no bumperette holes) Paint 6 of 10; Front hood repaint doesn’t match well Driver door has a few scrapes from PO Jersey barrier rub All rubber in very good shape Rear trunk key/actuator deleted by inside cable release Interior: Black Interior in very good condition CHT, Ammeter, Oil pressure gauges added Momo steering wheel with Porsche horn button Inside mechanical trunk release; Electric windshield washer Debounced tachometer (doesn’t jump around when revving or shifting) AM/FM CD Player Fire extinguisher mounted under passenger seet Have New Windshield to install; original is developing a crack (3 inches). Engine: 2L with stock Fuel Injection Unknown rebuild history Runs very well; doesn't smoke; doesn't leak oil Pertronix electronic points Stainless Steel Heat Exchangers Heat flappers recently sandblasted, painted Stainless Steel connect pipes from SSHE to flappers Front mounted fuel pump Fuel tank recently cleaned & repainted Bursch sport muffler w/chrome tip Optima red top battery Transmission: New clutch, pressure plate, throwout bearing, transmission main shaft seal, clutch cable Sideshift transmission; shifts very well; can get 1st gear easy while moving Oil changed last year Front Suspension: From low mile 1987 911 Carrera including: struts, hubs, calipers, Aluminum crossmember, steering rack, underbody swaybar, A-arms, T-bars, tie rods Rear Suspension: 180lb progressive rate springs, Koni adjustable shocks, stock swaybar, Eric Shea 5 lug drilled hubs, new bearings, stiffened swing arms Stiffened trailing arms Brakes: Front: 911 3.5inch A calipers Rear: rebuilt (3 years ago) stock rear calipers Functional front brake pad wear sensors (brake light flashes when pads worn) 19mm Brake Master Cylinder Rear Brake Proportioning Valve replaced by T HISTORY **************************** The only history of the car I could find that it was owned for many years by a gentleman in CT. Racer Chris did some work for him including the time he hit a Jersey barrier with the left rear corner and he replaced the trailing arm and brake caliper. In April 2002 Chris did the PPI for a 914 board member. At that time the car ran well, had good compression on all cylinders and needed no rust repair at all. I bought the car in March 2006. At some time in the past the car was hit on the drivers front. The inner wheel well was creased and the front panel behind the bumper was replaced. The hood was repainted at this time. See much of the work I’ve done to the car in this thread: Progress Thread Attached image(s) |
Lo-Fi Version | Time is now: 25th June 2024 - 12:05 AM |
