To Switch or Not to Switch, Now is the Time for the Question! |
bandjoey |
Nov 28 2008, 09:22 AM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I have the 73 1.7 that came with the single Solex 2bbl carb. I can't afford to do the engine rebuild probably until summer. I also have in the box a set of twin (both sides) Dellorto 36 carbs. I know the car runs bad using the Solex. I know the car won't run right with the Delortto's and the stock cam. The FI is mia and the PO said no chance of recovery.
Is there anything to gain right now puttin on the Dellortos or should I just wait until motor rebuild time? (IMG:style_emoticons/default/blink.gif) Thanks |
So.Cal.914 |
Nov 28 2008, 09:57 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Yes the cam is wrong but the two 36's , as said above should run better.
Lo-Fi Version | Time is now: 26th September 2024 - 12:08 PM |
