Nana's_914 |
Member ![]() ![]() Group: Members Posts: 98 Joined: 27-October 06 From: San Diego, CA Member No.: 7,100 Region Association: Southern California ![]() |
What needs to be done to make the 911 speedo function with a 915/61 that had the diff flipped? The pickup needs to be on the other side, right? Where should it go and how?
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
What needs to be done to make the 911 speedo function with a 915/61 that had the diff flipped? The pickup needs to be on the other side, right? Where should it go and how? I am guessing here...but it may give you a good place to start looking. If its an electronic speedo its probably using a hall effect sender. With these senders the magnet is in the speedo and could just be a tab on the ring pinion shaft or drive shaft at the back of the case...not sure. Take a look at the sender and see what metal tab passes through the sender body to create the magnetic field... Rich |
Lo-Fi Version | Time is now: 28th June 2024 - 03:42 PM |
