firewall (internal) insulation |
zeezee |
Dec 2 2008, 03:12 PM
Member Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
Is the tarish/rubber padding behind the backpad and glued to the firewall worth keeping? I'm assuming it's mainly for sound insulation.
Would I be better off replacing it with Dynamat type insulation? I've had to scrape the tar off the floors under the seats - and will be replacing that with Dynamat type insulation ... why not do more? Doors too? Actually I'll be using RAAMmat BXT - if there are any opinions out there... |
VaccaRabite |
Dec 2 2008, 05:15 PM
En Garde! Group: Admin Posts: 13,544 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I went with Raamat with mine. The layer of foil helps with sound deadening. I am not going to do the engine side of the firewall unless the noise is really bad, and I think I'd do a second layer on the cabin side before I put a layer on the engine side. in the event of a fire, it would also be less of something that might burn.
Zach |
Lo-Fi Version | Time is now: 21st September 2024 - 07:12 PM |
