zeezee |
Member ![]() ![]() Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California ![]() |
Is the tarish/rubber padding behind the backpad and glued to the firewall worth keeping? I'm assuming it's mainly for sound insulation.
Would I be better off replacing it with Dynamat type insulation? I've had to scrape the tar off the floors under the seats - and will be replacing that with Dynamat type insulation ... why not do more? Doors too? Actually I'll be using RAAMmat BXT - if there are any opinions out there... |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,197 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
I used two layers of RAAMmat, a layer of their foam and then a layer of Perlon to look like the 914-6 GTs, no problems, pretty easy install.
T.C. zeezee, (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 20th June 2024 - 06:20 AM |
