Overfilled Oil is my Front Seal Now trashed?, one quart more than capactiy, now leaks from front |
budman5201 |
Dec 7 2008, 11:53 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
I dropped my engine over the past week to fix misc oil leaks....oil cooler, front main seal, and the pushrod tubes. All leaked looked fixed but i accidentally overfilled oil by one quart. (drained oil while on ramps, and then refilled with 4 quarts) So i believe that there was one quart still i there when i refilled it 4 quarts on oil change. The dipstick measured 1 quart overfilled when checked.
I only ran it 5 minutes on ramps to get it up to temperature to make sure everything was allright then shut off. The front main seal (looks like from the leak up front dripping from front of fan shroud) like it is leaking. It has a brand new front main seal, IS it TRASHED now? Of am i just seeing the left over oil from the initial overfill thats still in the fan shrould? It now measures EXACTLY right below top notch on dipstick, maybe a hair below.... It leaks still front front of engine, not as fast, but drips a lot. |
SLITS |
Dec 8 2008, 08:09 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
My guess would be that you cut the lips on the seal when installing it or it's leaking from the oil pump gasket itself.
To blow the lips of the seal outward, you would have had to developed a high pressure in the crankcase. Possibilites are plugged PCV valve, plugged head breather ports. I have routinely run an engine 1/2 - 1 quart over, especially if running an AutoX. Well, that's my guess. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:20 AM |
