ice Needed on Front Shocks/Struts, Koni/Boge, Early vs. Late |
andys |
Dec 16 2008, 02:20 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Got one good opinion "over there". Soliciting others.
I've got two options on shocks if indeed they are interchangeable. I'm doing a 911 front swap from a '89 Carrera. These are Boge struts with gas shocks; the black ones in the photos below. When I disassembled the 914 struts, I found Koni adjustable inserts. The red shocks in photos below. Should I consider trying to adapt the Koni inserts into the Boge struts? I seem to recall someone did a nice write-up on the different interchanges, and I think Koni inserts fit the Boge struts with a certain mix of parts (retaining spanner, spacer, etc). Since I have a machine shop, I can make whatever spacers I need if the adaption is even possible or worthwhile. Another question I have has to do with which shock would be better suited to my setup. My car is a LS1 V8 swap with 6 speed trans. I have Koni double adjustable (Yellow) rear coil overs with 200# springs, Engman chassis stiffening kit and suspension ear reinforcement. The front T-bars are stock Carrera (18.8mm?). I would prefer to get the shocks reasonably close to matching the T-bars and the weight of the car. This is mainly a street car with of course a couple of visits to Willow Springs for a HPDE or two. Opinions? Thanks, Andys Attached image(s) |
MLedesma |
Dec 17 2008, 09:49 AM
Member Group: Members Posts: 52 Joined: 13-October 06 From: Elizabeth, CO Member No.: 7,036 Region Association: Rocky Mountains |
Uhmm, correct me if I am wrong but your Boge struts look like they actually have Bilstein inserts in them. Boge struts usually have a much thinner extension (similar to the Koni) on them. It looks like somebody did exactly what you except using the Bilstein instead.
Matt |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:25 PM |
