andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Got one good opinion "over there". Soliciting others.
I've got two options on shocks if indeed they are interchangeable. I'm doing a 911 front swap from a '89 Carrera. These are Boge struts with gas shocks; the black ones in the photos below. When I disassembled the 914 struts, I found Koni adjustable inserts. The red shocks in photos below. Should I consider trying to adapt the Koni inserts into the Boge struts? I seem to recall someone did a nice write-up on the different interchanges, and I think Koni inserts fit the Boge struts with a certain mix of parts (retaining spanner, spacer, etc). Since I have a machine shop, I can make whatever spacers I need if the adaption is even possible or worthwhile. Another question I have has to do with which shock would be better suited to my setup. My car is a LS1 V8 swap with 6 speed trans. I have Koni double adjustable (Yellow) rear coil overs with 200# springs, Engman chassis stiffening kit and suspension ear reinforcement. The front T-bars are stock Carrera (18.8mm?). I would prefer to get the shocks reasonably close to matching the T-bars and the weight of the car. This is mainly a street car with of course a couple of visits to Willow Springs for a HPDE or two. Opinions? Thanks, Andys Attached image(s) ![]() ![]() ![]() |
andys |
Matt,
Sorry I'm not particularly Porsche fluent, but I wasn't aware that Bilstein inserts will fit the Boge struts; anyone?? brp986s, As a past racer, I always look toward adjustability options as I realize how important it is to tune the suspension to the conditions (street or track). I think the 914 T-bars are 17mm. The Porsche torsion bar conversion table I have differs significantly from the info you posted; do you perhaps have a link? Maybe someone has yet another conversion table (or link) to help establish the correct info? BTW, does the foam T-bar seal go between the A-arm and the cross member, or between the cross member and the T-bar adjuster cap? Thanks, Andys |
brp986s |
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 ![]() |
Matt, Sorry I'm not particularly Porsche fluent, but I wasn't aware that Bilstein inserts will fit the Boge struts; anyone?? brp986s, As a past racer, I always look toward adjustability options as I realize how important it is to tune the suspension to the conditions (street or track). I think the 914 T-bars are 17mm. The Porsche torsion bar conversion table I have differs significantly from the info you posted; do you perhaps have a link? Maybe someone has yet another conversion table (or link) to help establish the correct info? BTW, does the foam T-bar seal go between the A-arm and the cross member, or between the cross member and the T-bar adjuster cap? Thanks,: Andys the table is in a pdf that I have. In it is mention of http://tech.rennlist.com |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:16 PM |
