914.356.202.00 - Rubber Sleeve, ...for main fuel line running through the rear fire wall |
Zimms |
Dec 28 2008, 09:12 PM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
I tore this part and started to look for a repacement at all of the typical sources, PP, AA, GPR, adn even the local dealer. The PET catalog calls this part out as a "rubber Sleeve". A search on these sites and the dealer for this part number brings up a "Drain Brush" and it is NLA. In the long run, I can just use the return line part, 914.356.201.00 and take material out of the ID to match the main line diameter.
BUT, now I am curious. The 914.356.201.00 is readily available. Why would one be available and the other not? Why the difference in description from the PET to "Drain Brush"? Both parts had another set of numbers molded into the top lip along with the part number. They didn't help me track down the original, but they are: 914.356.201.00 - 48107 2 33 914.356.202.00 - 48107 A2 24 Anyone else run across this? |
Lo-Fi Version | Time is now: 25th September 2024 - 10:50 PM |
