blabla914 |
I like primer ![]() ![]() Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None ![]() ![]() |
Just so you know, I'm not looking to build some killer SM2 914. I just like autocrossing my street car and the old club that was REAL loose with the rules lost their site a couple years ago. Now I'm looking at potentially running some SCCA events and since I used to work registration for a couple different local clubs I hate it when people have no idea what class their car can even run in much less how their mods fit in the different classes.
From the SCCA rule book chapter 16, Street Mod & SM2 16.1 G. Subframe connectors are allowed as per Street Prepared (15.2.E). 15.2 E subframe connectors E. Longitudinal (fore-aft) subframe connectors (“SFCs”) are permitted with the following restrictions: 1. They must only connect previously unconnected boxed frame rails on unibody vehicles. 2. Each SFC must attach at no more than three points on the unibody (e.g. front, rear, and one point in between such as a seat mount brace or rocker box brace). 3. SFCs must be bolted or welded, but welding must be to the OE subframe stampings, not to the floor pan in between. 4. No cutting of OE subframes or floorpan stampings is permitted. Drilling is permitted for mounting bolts only. 5. No cross-car/lateral/triangulated connections directly between the driver’s side and passenger’s side SFCs are permitted. Connections to OE components such as tunnel braces or closure panels via bolts are allowed and count as the third point of attachment. No alteration to the OE components is permitted. 6. SFCs may not be used to attach other components (including but not limited to torque arm front mounts or driveshaft loops) and may serve no other purpose. Seems to me the Brad Mayeur kit and clam shells violate items 1,2 &, 3 and the Engman kit since it goes across the fire wall and joins the two sides adds item 5 to the list of reasons it is not legal. Let me know how you interpret these rules. Kelly |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Have any of you looked at a real SM2 car? OMG there is a lot going on that it just stupid. I decided not to build an SM2 car because it would be too expensive. Cage is legal but also pretty heavy. which requires more power and more brakes. bigger than 275 wide tires. The class is structured for newer cars. Plus 80K in upgrades.
I am pretty much going XP because I think the 914 is faster when lighter. I already have 2316 Raby kit. and a car to completely gut (Shit box with a roof). XP is more run what ya brung and to me is cheaper |
blabla914 |
Have any of you looked at a real SM2 car? OMG there is a lot going on that it just stupid. I decided not to build an SM2 car because it would be too expensive. Cage is legal but also pretty heavy. which requires more power and more brakes. bigger than 275 wide tires. The class is structured for newer cars. Plus 80K in upgrades. Yes, I am familiar with what comprises a "real" SM2 car, but you probably have more knowledge of what it would actually take to build a "real" SM2 car than I do. Are you saying that a lot of the SM2 cars you've seen are doubling chassis members like an Engman kit does? I can totally see why you would go the XP route instead of SM2. I haven't really been involved with SCCA since SM came on the scene. I just want make sure I run my car in a class where I'm not way outside the rules. If I can tailor future mods to a specific category like Prepared vs Mod I so much the better. Kelly |
Lo-Fi Version | Time is now: 20th June 2024 - 06:05 AM |
