> New Project: Grassroots Motorsports $2010 Challenge Car
camaroz1985
post Jan 6 2009, 03:09 PM
Just thought I would post up a quick picture of my newest project.
(IMG:http://i254.photobucket.com/albums/hh87/camaroz1985/914/PIC-0088.jpg)
Its a '75 that I will be building for the $2009 Challenge. There is no engine now, and I am still trying to figure out what I will be using.
I think about 200hp should be good enough if I can keep the weight down. I figure I have about $750 for engine and cooling system (or preferably a parts car that I can get everything from).
What do you guys think? What are my best options? Who has cheap parts they want to sell to help the cause (IMG:style_emoticons/default/biggrin.gif)
I'll update this as I progress.
camaroz1985
post Jan 6 2009, 03:44 PM
I already have budgeted the $550 for the Kennedy adapters, and that is not included in the $750 i listed.
What kind of power can you get out of a turbo type IV, and how much will it cost me to get it. If i went that way I would have $1300 to spend, but would prefer to put more into suspension stuff. So what could I get out of one (plus the purchase of the motor) for $1000.
ottox914
post Jan 6 2009, 04:23 PM
The glory that once was.
QUOTE(camaroz1985 @ Jan 6 2009, 01:44 PM) *
How long do you want/need it to last?
You'll need to hack/bend up some sort of exhaust and flange to mount the turbo. For a rat rod git-r-done type of deal, I'd move the battery to the trunk, and mount the turbo up in that area. The stock EFI will laugh at you then run lean and hole a piston, no way it can deal with positive manifold pressure. Doing this on the cheep, I'd do a draw thru carb set up. Its very old school, but should keep you under $2009. If the event is run in warmer temps, that will help you out, as the draw thru systems don't work well in colder temps. Since you can't use an intercooler with a draw thru system, I'd rig up a cheep water injection system to keep the charge temps down. The T-IV pistons have the rings mounted way up high on the piston, which will expose them to alot of the pressure of the boost when things heat up in the cyl, so keeping things cool will go along way toward keeping the motor together and the ring lands from cracking.
How much boost?
How long do you want/need it to last.
I've read on Jake's forums of guys running up to 20psi on stock internals, but the pistons don't last. And they have a ton of motor cooling and intercooling. And $$$ in the project. If you want it to last for exactly 1 weekend, and you're willing to take a 50/50 bet if it'll even last that long, go for 20 psi and let us know how far the pieces go when it scatters. Longer term use, shoot for 10psi, and if you want to push your luck, go for 15. If they run the autox before the drags, maybe run 15 for the cones, and bump to 20 and some NOS for the drag...
How much power will that all be? No clue. Never got mine to a dyno last year.
How much cost?
What are your options for the exhaust system? Can you scare up some tubing, cut and weld on your own, or do you need to farm this out? Lets say 100 in materials for tubing/flange material. 50-200 for a used turbo. Look for a small one, like the front or back turbo off a mitzu 3000gt, a 9B turbo. Another couple hundred for a side draft carb of some sort. If you're using the stock 914 fuel pump, a regulator to dial down the fuel pressure. $500 bucks and alot of imagination might do it, with some sharp shopping and lots of free labor.
With my built motor I'm looking to make 15psi, but also to make it for a good long time. I have no interest in dropping the motor every winter to re-re-re build it again. I'm building the long block around the idea of making the most airflow I can at low rpms so I can spool the turbo quicker, and let the turbo make the power beyond that. More interested in torque than HP. I'm running a 3000gt turbo, and on a stock 2.0 motor, boost started by 2500, was all in by 3500 or so, and pulled hard to the 10psi boost cut. If I make 200/200 at the wheels, I'd be pretty happy, but I'll build it and see what I end up with, and whatever that is, it'll be better than what it is now. I'd love to see 10psi by 2500, and 15 by 3500.
All this is very contrary to what I'm doing with my turbo car- stand alone ecu, ITB's, and now a boost friendly Raby motor, but for a fast ride on warm days for $2009 or less, I'd google up and research a draw thru set up, and spend more $$ on suspension and tires than motor.
If you're going turbo T-IV.
***edit: turbo T-IV forum: http://forums.aircooledtechnology.com/forumdisplay.php?f=34
***edit: draw thru turbo on a buggy: http://www.smbaker.com/rail/monsterturbovw.html
camaroz1985   New Project: Grassroots Motorsports $2010 Challenge Car   Jan 6 2009, 03:09 PM
jimkelly   if you use a non type 4 engine - you will run into...   Jan 6 2009, 03:19 PM
camaroz1985   I already have budgeted the $550 for the Kenn...   Jan 6 2009, 03:44 PM
r_towle   I already have budgeted the $550 for the Ken...   Jan 6 2009, 03:49 PM
old9one4   Serious question. How long does the motor need to...   Jan 7 2009, 11:03 PM
ottox914   I already have budgeted the $550 for the Ken...   Jan 6 2009, 04:23 PM
camaroz1985   For the purposes of the competition it only needs ...   Jan 6 2009, 03:56 PM
r_towle   you wont be able to stay on budget with anything e...   Jan 6 2009, 04:15 PM
camaroz1985   Ok so you think about $500 dollars shopping s...   Jan 6 2009, 07:23 PM
Zaney   I picked up a 2002 Subie 2.5L N/A engine and 5 spe...   Jan 6 2009, 09:36 PM
Todd Enlund   I picked up a 2002 Subie 2.5L N/A engine and 5 sp...   Jan 6 2009, 10:24 PM
jimkelly   good thread - http://www.914world.com/bbs2/index.p...   Jan 6 2009, 09:46 PM
camaroz1985   I picked up a 2002 Subie 2.5L N/A engine and 5 sp...   Jan 6 2009, 11:28 PM
Todd Enlund   I am hoping to do well in the autocross. The dra...   Jan 7 2009, 11:27 AM
Dr. Roger   do these spin the right way? http://sfbay.craigsl...   Jan 6 2009, 11:39 PM
camaroz1985   What about a NA Subaru 2.5 with a FWD transmission...   Jan 7 2009, 11:12 AM
r_towle   What are magic flanges??? Will they make me look t...   Jan 7 2009, 11:25 AM
Zaney   Magic Flanges thanks to Porcharu (Steve)   Jan 7 2009, 11:33 AM
camaroz1985   Thanks Zaney. I have seen those, but the price is...   Jan 7 2009, 11:37 AM
Todd Enlund   I woul just weld the two sets of axles together (...   Jan 7 2009, 12:08 PM
camaroz1985   Good idea with the front sway bar!! I was...   Jan 7 2009, 12:28 PM
Wes V   Why not think about buying a VW Passat for it...   Jan 12 2009, 08:54 PM
camaroz1985   Got some work done this weekend. It is getting li...   Jan 12 2009, 08:44 AM
rick 918-S   How much for the Harley? :drooley:   Jan 12 2009, 09:19 AM
camaroz1985   Sorry not for sale it is going to be restored. Wa...   Jan 12 2009, 09:23 AM
RJMII   How about the center console? and what sorts of pa...   Jan 12 2009, 09:30 AM
camaroz1985   Here are the rules Rules As far as I know trades...   Jan 12 2009, 09:48 AM
BIGKAT_83   Picked this up yesterday. Seems to run good. Start...   Jan 12 2009, 10:14 AM
camaroz1985   Nice an SVX. I'm hoping to be able to do the ...   Jan 12 2009, 10:42 AM
camaroz1985   Somebody else mentioned this to me Wes, and even o...   Jan 13 2009, 10:10 AM
camaroz1985   After some searching I've found a donor car fo...   Feb 22 2009, 09:12 PM
camaroz1985   Well the Impreza is stripped and gone. Made more ...   Mar 26 2009, 09:57 AM
dlo914   Nice score on the 94' Impreza! Our project...   Mar 26 2009, 11:34 AM
camaroz1985   Things have been a bit slow. I had to finish up w...   Jun 3 2009, 09:04 AM
Zundfolge   So just how old is that first pic (on the trailer)...   Jun 3 2009, 09:14 AM
camaroz1985   Just after this past Chrstmas.   Jun 3 2009, 09:20 AM
914forme   Nascar bars show up on ebay all the time, you can ...   Jun 7 2009, 05:13 PM
d914   on the cheap use the tranny,, take out the diff a...   Jun 7 2009, 08:22 PM
dlo914   Great progress...really wish we picked up a Subaru...   Jun 8 2009, 04:14 AM
BIGKAT_83   I'm doing my conversion on the cheap also. I...   Jun 8 2009, 06:09 AM
camaroz1985   Thanks for all the input guys. 914forme and d914,...   Jun 8 2009, 10:16 AM
BIGKAT_83   Thanks for all the input guys. BIGKAT_83, Looki...   Jun 8 2009, 10:46 AM
camaroz1985   Well the project is being pushed to 2010 and ...   Sep 22 2009, 10:46 AM
Jakeodoule   Check out the $500 challenge my brother and I...   Sep 22 2009, 12:42 PM
jpnovak   I just picked up a 75 teener for my $2010 GRM...   Sep 22 2009, 01:15 PM
type47   I just picked up a 75 teener for my $2010 GR...   Sep 22 2009, 02:35 PM
camaroz1985   EJ20G on a challenge budget, yeah I'd say that...   Sep 22 2009, 03:20 PM
camaroz1985   Well its been a while but I'm finally back in ...   May 10 2010, 12:05 PM
camaroz1985   After some thinking, and being realistic with myse...   Apr 4 2011, 09:32 AM
billh1963   Wow...look at those fuel prices on the first page...   Apr 13 2011, 01:19 PM
- Lo-Fi Version Time is now: 19th April 2025 - 01:01 PM
