My MicroSquirt Install |
McMark |
Jul 20 2008, 05:00 PM
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate. Anyway, now on the the fun stuff! I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today. Attached image(s) |
McMark |
Jan 6 2009, 07:21 PM
Yup, the timing gear is the exactly the same thickness as the stock washer. There is a picture, earlier in the thread, that shows the stock washer on top of the gear (Post #69). 100% non-modify installation. True bolt-on.
Bartlett 914 |
Jan 7 2009, 09:20 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Yup, the timing gear is the exactly the same thickness as the stock washer. There is a picture, earlier in the thread, that shows the stock washer on top of the gear (Post #69). 100% non-modify installation. True bolt-on. That would work. It is just that in that picture, the plate looks thicker. I assume is is reduced in thickness on the back side. Is this correct? |
Lo-Fi Version | Time is now: 28th June 2024 - 09:08 AM |
