Home made tools, Show us yours |
Bartlett 914 |
Jan 8 2009, 09:21 AM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
We all do it. We sometimes need a tool for a special use. It sometimes makes the difference in how well a job comes out Earlier this year, just for the heck of it, I removed the shaft from the bushings in an old trailing arm. I ended up using heat. I did get it out but what a an awful stinky mess! Yesterday Glenn (gms) stopped by with 2 trailing arms he was cleaning up. He wanted to know if I had a press for the job. With a little scrap metal some machining and welding we came up with a simple tool to remove the shaft. Here are a couple pictures of what we came up with. The tool worked really nice. I think if wanted, this would also work with the trailing arm in the car.
So how about posting some of the special tools you have made. Attached image(s) |
zambezi |
Jan 9 2009, 01:18 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Heres an engine stand I built for storing and running our 356 engines. Would also work for vw engines, just change the starter if its 12Volt. There is a Harley oil tank converted for a fuel tank in the differential space of the trans, and where the gear sets would be is the fuel pump and filter. LED lights on top of the trans are for oil pressure and ignition (so as not to leave the key in the on position if not running the engine).
Attached image(s) |
Lo-Fi Version | Time is now: 27th December 2024 - 06:46 PM |
