McMark |
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate. Anyway, now on the the fun stuff! I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today. Attached image(s) ![]() ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The D-jet points only hook up to the ECU, not to the coil. Each one triggers once per full cam revolution (two crank revolutions), not four times. It would probably work OK as an RPM indication, but not so good indicating crank or cam position.
Plus the D-jet distributors are old and sloppy. Controlling the spark directly is much much more precise. --DD |
Lo-Fi Version | Time is now: 25th June 2024 - 07:04 PM |
