Zeke |
Never left, but not right.... ![]() ![]() Group: Members Posts: 382 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None ![]() |
I've always thought that the best way to begin a project is to ask those who have been there before.
I have a 914 here and some GT fenders to weld on. Being somewhat of a panel beater and welder, I'm going to use the typical methods, Clecos for mock up, panel clamps for alignment and a MIG welder to tack. The only departure from what I've done in the past is that I'm going to butt weld the fenders using oxy/acetylene with a micro (or aircraft torch) and some ER70S-6 rod, which is very malleable post weld. I will dolly all the welds as I go before any grinding. If necessary, I will shrink as I go as well. From the best info I can find, this is how the factory did things like GT's and some of the 911 factory race cars. I usually go over my welds with a light on the back side looking for pinholes and braze them. As further insurance, I use lead over the seem as needed to finish. However, I know there are a couple of pitfalls to watch for and that's why I'm posting. I've seen some incredibly nice work here. I hope to be that best welds thread for 2009. (IMG:style_emoticons/default/smile.gif) |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Hi Zeke,
To the poster...torch/hammer weld will certainly make your weld alot more workable...mig weld suck to hammer..they crack. Torch creates alot more heat and you will need to be carful as you weld over the top of the flare..the top area will warp and deform if you go to fast. One trick a hot rod guy showed me that works great is to have your 4 inch grinder all setup with a wire wheel and ready to go. Weld a bit, then immediately pick up the grinder and wire brush the area you just welded to spread out the heat quickly and dissapate the heat...it works great. I hate brass....it sucks under paint and tends to create all sorts of problems with modern paints...I have a nice small area to fix on my car due to brass...I would not use it, just stick with lead and allmetal. Rich |
Lo-Fi Version | Time is now: 20th June 2024 - 06:23 AM |
