914junkie |
Member ![]() ![]() Group: Members Posts: 167 Joined: 14-December 08 Member No.: 9,848 Region Association: None ![]() |
Ok, so I think I'm ready to install a roll cage in my 73 914 V8. I was thinking about going with an Autopower for an easy install since I lack welding skills. I have friends that could weld the feat in and I can do the rest. Anyone installed an Autopower in their car? And will my harness bar still fit? Any advice would be helpfull. Thanx, Paul. (IMG:style_emoticons/default/beer3.gif)
byndbad914 |
shoehorn and some butter - it fits ![]() ![]() ![]() Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None ![]() |
(IMG:style_emoticons/default/agree.gif) Josh beat me to it. Sit in your car, centered in the seat, put your belt on and get it locked into place and move your body around trying to hit the A pillar and B pillar... going to have a VERY difficult time pulling that off, or else sell the car it is a death trap. You will typically be able to bust the door window out with your head in a side impact but that should be about it.
Add a cage that is 2-3" closer than those items between gaps and tubing size itself, make it ROUND not flat like a B pillar so you can really crush an area of your skull - do the same thing... won't be hitting the A pillar, the cross bar across the top of the windshield (the hoop)... maybe but probably not, but the B pillar area and the bar immediately behind your head hoop, probably so. I built the cage in my car custom to tuck everything as tight as possible, moved the seat inboard almost 2" to center up on the wheel (and rotated the steering column to match) and I can't hit the bars with my head and have 1" of clearance in general. WITH the padding, I can just touch the front of the hoop with my thick, top air helmet, so in a big crash I will make contact with the thick SFI padding but not worried. Keep in mind SA rated helmets v. M rated helmets have the additional testing for hitting roll bars, because the initial contact is a point (sphere on cylinder) and only becomes line contact as the helmet deflects, so force is distributed over very small areas. If that is your skull... hope you enjoy eating your meats and starches with a straw. So, my point (I am long winded)... you can do a cage, but relocate your seat and make damn sure you have at least 1" (IMO) of clearance straining against the belts in any direction. I would make sure that is including padding - don't ever "expect" your head hit anything, period - do all you can to avoid contact with your noggin. That SFI padding will kill you just as quickly with no helmet - it only serves to increase the area of contact for your helmet, the force is still brutal. |
Solo914 |
Member ![]() ![]() Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None ![]() |
(IMG:style_emoticons/default/agree.gif) Josh beat me to it. Sit in your car, centered in the seat, put your belt on and get it locked into place and move your body around trying to hit the A pillar and B pillar... going to have a VERY difficult time pulling that off, or else sell the car it is a death trap. You will typically be able to bust the door window out with your head in a side impact but that should be about it. Add a cage that is 2-3" closer than those items between gaps and tubing size itself, make it ROUND not flat like a B pillar so you can really crush an area of your skull - do the same thing... won't be hitting the A pillar, the cross bar across the top of the windshield (the hoop)... maybe but probably not, but the B pillar area and the bar immediately behind your head hoop, probably so. I built the cage in my car custom to tuck everything as tight as possible, moved the seat inboard almost 2" to center up on the wheel (and rotated the steering column to match) and I can't hit the bars with my head and have 1" of clearance in general. WITH the padding, I can just touch the front of the hoop with my thick, top air helmet, so in a big crash I will make contact with the thick SFI padding but not worried. Keep in mind SA rated helmets v. M rated helmets have the additional testing for hitting roll bars, because the initial contact is a point (sphere on cylinder) and only becomes line contact as the helmet deflects, so force is distributed over very small areas. If that is your skull... hope you enjoy eating your meats and starches with a straw. So, my point (I am long winded)... you can do a cage, but relocate your seat and make damn sure you have at least 1" (IMO) of clearance straining against the belts in any direction. I would make sure that is including padding - don't ever "expect" your head hit anything, period - do all you can to avoid contact with your noggin. That SFI padding will kill you just as quickly with no helmet - it only serves to increase the area of contact for your helmet, the force is still brutal. Guess I never sat in a caged 914. After moving the seat and steering column you are still only an inch away... that is close. I am that way in my SM and thats with the SFI padding but I wish my A pillar tube was even tighter to the top. We have talked about this at length locally because we have some guys that drive their track cars to the track and the sentiment is that you shouldn't drive a fully caged car on the street, and if you HAVE to, make sure that you pad the shit out of the cage and where your 5 point harness. Kyle |
Lo-Fi Version | Time is now: 26th June 2024 - 02:43 PM |
