> What turbo should I buy?
turnaround89
post Jan 9 2009, 09:20 PM
I am getting ready to turbo my 1.8L engine. And I already know that you can't turbo a 914. But, what i would like to know is what are good cars to get turbo's off of?
I am looking for a small turbo that will spool quickly. Looking to run about 7 to 10 pounds of boost.
What turbo'd cars will give me a good turbo to use? I have been looking for ones on ebay, but don't really want to buy one there. I don't mind buying a used one, so going to the junkyard and getting one is definitely an option.
Which turbo?
turnaround89
post Jan 15 2009, 08:10 PM
Most modern turbos offer an intake seal (are they still carbon face seals?)
No, most turbos, come with a dynamic seal, which will not work with draw through, like you mentioned. I have read over monster turbocharged volkswagon about how to actually change to a carbon seal. the hard part about changing to a carbon seal, is finding the thrust collar and carbon seal plate. I have not located those parts yet, well, i located the thrust collar, but you have to buy the whole rebuild kit which i don't want to have to do since the turbo will be brand new. I guess a couple extra parts never hurt.
Im totally aware of the possible screw ups that can/may happen. Learn by your mistakes. It may be expensive that way, but if thats what it takes to learn how to run a turbo, then so be it. If i screw up, ill try again, until i get it right.
when all else fails, try, try, try again!!
rtalich
post Jan 15 2009, 08:43 PM
QUOTE(turnaround89 @ Jan 15 2009, 06:10 PM) *
My 2 cents... Why put yourself thru the trouble? Why not take advice from experienced people and do it right the first time? Why do you think you need to experience the failures for yourself in order to learn how to implement a turbo? If you're trying to accomplish this on a tight budget then it sounds like Dave's implementation is the way to go and he has documented it pretty well.
Its just hard to read posts like this and not chime in... sounds like theres nothing anyone can do to pursuade you either way. You could still do it the right way and still learn a thing or two. Or, in this case, listen to peolpe that have been in your shoes, wanting to boost their type IV and have done it successfully through trial and error. Just trying to save you some $$$$ dude.
nein14
post Jan 15 2009, 09:05 PM
QUOTE(rtalich @ Jan 15 2009, 06:43 PM) *
I have to disagree with the tight budget of Dave's implementation, his SDS injection alone was most likely more than cost of all my parts used in my conversion.
Also from what I read in his build thread it did not run that long sucessfully for a extended time period without issues.
rtalich
post Jan 15 2009, 09:38 PM
QUOTE(nein14 @ Jan 15 2009, 07:05 PM) *
OK... bad example, I guess. It is well documented to say the least. Just wanted to get a point across.
turnaround89   What turbo should I buy?   Jan 9 2009, 09:20 PM
iamchappy   I would think something matched to your displaceme...   Jan 9 2009, 09:27 PM
scotty b   I would think something matched to your displacem...   Jan 9 2009, 09:32 PM
carr914   Screw it, get a BIG MoFo   Jan 9 2009, 09:40 PM
turnaround89   I think i have read all the turbo stuff there is o...   Jan 9 2009, 09:41 PM
iamchappy   hmmmmm.   Jan 9 2009, 10:02 PM
turnaround89   iamchappy....should i rethink my setup and go with...   Jan 9 2009, 10:28 PM
iamchappy   iamchappy....should i rethink my setup and go wit...   Jan 10 2009, 08:07 AM
RJMII   You planning on running carbs and a turbo? side dr...   Jan 10 2009, 12:11 AM
Dr Evil   I am considering using my corvair turbo and side d...   Jan 10 2009, 12:15 AM
Nana's_914   I would look in the junk yard for a turbo from a M...   Jan 10 2009, 01:25 AM
turnaround89   Just wondering iamchappy, thats all. I plan on ru...   Jan 10 2009, 09:31 AM
plymouth37   I think this would be a perfect match for your dri...   Jan 10 2009, 10:15 AM
sww914   I think this would be a perfect match for your dr...   Jan 10 2009, 11:57 AM
Joe Sharp   I think this would be a perfect match for your dr...   Jan 10 2009, 01:26 PM
nein14   I am getting ready to turbo my 1.8L engine. And ...   Jan 10 2009, 11:48 AM
Nana's_914   If you you want to run a significant level of boos...   Jan 10 2009, 01:02 PM
Dr Evil   How about this one? Internal wastegate. http://cgi...   Jan 10 2009, 02:16 PM
Dr Evil   Cheaper one. http://cgi.ebay.com/ebaymotors/T3-T4-...   Jan 10 2009, 02:24 PM
RJMII   Cheaper one. http://cgi.ebay.com/ebaymotors/T3-T4...   Jan 10 2009, 02:26 PM
RJMII   http://cgi.ebay.com/ebaymotors/T3-T4-Hybri...A1%7C...   Jan 10 2009, 02:28 PM
Dr Evil   Small hijack, but may help this thread as well as ...   Jan 10 2009, 02:35 PM
RJMII   how about a link? http://www.ztechz.net/id4.html...   Jan 10 2009, 02:44 PM
turnaround89   Would have replied sooner, but i had to work today...   Jan 10 2009, 07:51 PM
RJMII   On the first link to an ebay turbo, what is the ...   Jan 10 2009, 11:14 PM
turnaround89   Thanks for the answers RJMII, i had to read throug...   Jan 10 2009, 11:31 PM
Nana's_914   I think a Garrett GT2052 is a pretty good match fo...   Jan 11 2009, 02:16 PM
ottox914   Some thoughts for you- Chappy beat me to the link ...   Jan 11 2009, 02:40 PM
Dr Evil   Ah, thems the books I was inquiring about :) If I ...   Jan 11 2009, 03:02 PM
ottox914   Ah, thems the books I was inquiring about :) If I...   Jan 11 2009, 03:36 PM
Dr Evil   I got both of the books from Amazon for the cost o...   Jan 11 2009, 05:47 PM
nein14   I got both of the books from Amazon for the cost ...   Jan 11 2009, 07:55 PM
RJMII   http://www.914world.com/bbs2/uploads/post-262-12...   Jan 15 2009, 12:50 PM
turnaround89   Not to be mean here either ottox914, but not kno...   Jan 11 2009, 09:04 PM
nein14   :popcorn:   Jan 11 2009, 09:23 PM
charliew   My son mildly ported his 2.5 sti heads with stock ...   Jan 11 2009, 09:23 PM
turnaround89   Apparently everyone thinks that im not willing to ...   Jan 11 2009, 10:07 PM
RJMII   Apparently everyone thinks that im not willing to...   Jan 11 2009, 11:01 PM
Dr Evil   I think everyone needs to play nice here. The lad ...   Jan 11 2009, 10:59 PM
turnaround89   Thats the whole reason i started this thread, lear...   Jan 12 2009, 12:14 AM
ottox914   Dude- sorry we/me rubbed you the wrong way. Chill ...   Jan 12 2009, 08:54 AM
andys   Just a quick comment; I'd look to keeping the ...   Jan 12 2009, 11:01 AM
iamchappy   Just a quick comment; I'd look to keeping the...   Jan 12 2009, 02:43 PM
RJMII   [quote name='andys' post='1120779' date='Jan 12 2...   Jan 12 2009, 04:12 PM
ottox914   Just a quick comment; I'd look to keeping th...   Jan 12 2009, 04:37 PM
andys   Just a quick comment; I'd look to keeping th...   Jan 12 2009, 06:32 PM
turnaround89   After some pm's i had with RJMII, i am gonna l...   Jan 12 2009, 02:33 PM
nein14   After some pm's i had with RJMII, i am gonna ...   Jan 12 2009, 05:06 PM
rusty914   After some pm's i had with RJMII, i am gonna...   Jan 15 2009, 01:51 PM
turnaround89   10, probably won't happen on my car, maybe put...   Jan 12 2009, 02:51 PM
Dr Evil   We should have a separate turbo 914 forum just for...   Jan 12 2009, 05:34 PM
ottox914   We should have a separate turbo 914 forum just fo...   Jan 12 2009, 07:07 PM
RJMII   We should have a separate turbo 914 forum just f...   Jan 12 2009, 07:31 PM
Dr Evil   Some pics I poached :)   Jan 12 2009, 05:47 PM
iamchappy   there used to be a site here. http://www.914turbo...   Jan 12 2009, 07:39 PM
rusty914   :popcorn:   Jan 12 2009, 07:45 PM
charliew   nein14 seems to have a very good cost effective so...   Jan 12 2009, 10:46 PM
RJMII   What that gold thing does. =o) I went and took m...   Jan 12 2009, 11:20 PM
ONTHEGRIND   What that gold thing does. =o) I went and took ...   Jan 13 2009, 05:47 PM
RJMII   What that gold thing does. =o) I went and took...   Jan 13 2009, 07:21 PM
biggy72   I haven't had a chance to read through all of ...   Jan 13 2009, 12:06 PM
FourBlades   Go big: This Porsche owner has the right idea a...   Jan 13 2009, 04:44 PM
turnaround89   Dr. Evil - you just nailed exactly what my exhaust...   Jan 13 2009, 04:51 PM
turnaround89   Ok, since im in the decision making process of efi...   Jan 13 2009, 08:14 PM
RJMII   I'm going to go ahead and just sit back and wa...   Jan 13 2009, 08:23 PM
turnaround89   Found what i was looking for!   Jan 13 2009, 09:10 PM
ONTHEGRIND   With a carb you need to be sure that the fuel p...   Jan 13 2009, 09:19 PM
ottox914   More reference material: Turbocharging Performance...   Jan 14 2009, 09:50 PM
nein14   More reference material: Turbocharging Performanc...   Jan 15 2009, 08:17 AM
RJMII   That is a costly build concept, we all learn fro...   Jan 15 2009, 12:59 PM
turnaround89   That was the method with the baja bug, build it, b...   Jan 14 2009, 10:21 PM
charliew   I think I posted earlier it will be a lot less exp...   Jan 15 2009, 12:52 PM
turnaround89   Ive been looking at a lot of type 1's with tur...   Jan 15 2009, 03:06 PM
andys   I still have a question that i have not gotten a...   Jan 15 2009, 03:33 PM
nein14   Ive been looking at a lot of type 1's with tu...   Jan 15 2009, 07:49 PM
turnaround89   Awesome, because i have been looking into draw thr...   Jan 15 2009, 05:29 PM
andys   Awesome, because i have been looking into draw th...   Jan 15 2009, 06:41 PM
Pat Garvey   I am getting ready to turbo my 1.8L engine. And ...   Jan 15 2009, 07:35 PM
turnaround89   No, most turbos, come with a dynamic seal, which...   Jan 15 2009, 08:10 PM
rtalich   Im totally aware of the possible screw ups that c...   Jan 15 2009, 08:43 PM
nein14   Im totally aware of the possible screw ups that ...   Jan 15 2009, 09:05 PM
rtalich   [quote name='rtalich' post='1122286' date='Jan 15...   Jan 15 2009, 09:38 PM
andys   Long ago: The '63 Olds turbo needed a new carb...   Jan 15 2009, 09:05 PM
nein14   Long ago: The '63 Olds turbo needed a new car...   Jan 15 2009, 09:07 PM
iamchappy   I agree with the others on this, learn from the wi...   Jan 15 2009, 09:10 PM
turnaround89   I am taking the advice from the experienced people...   Jan 15 2009, 10:37 PM
ottox914   Reading and understanding are one thing, blowing ...   Jan 15 2009, 10:46 PM
andys   Back to the project at hand: Draw thru would not...   Jan 15 2009, 11:09 PM
turnaround89   Frigid temps are normal here in rockford, we had a...   Jan 15 2009, 10:59 PM
turnaround89   After looking over some more pictures of setups, b...   Jan 15 2009, 11:27 PM
rusty914   After looking over some more pictures of setups, ...   Jan 16 2009, 02:14 PM
andys   Did you try these forums and sites? The JY Turbo f...   Jan 16 2009, 11:51 AM
turnaround89   Aren't they beautiful. Ive heard of turbo l...   Jan 16 2009, 02:32 PM
rusty914   http://www.914world.com/bbs2/index.php?sho...mp;hl...   Jan 17 2009, 11:50 AM
rusty914   Excellence article http://rides.webshots.com/phot...   Jan 17 2009, 12:12 PM
turnaround89   A little update and change of ideas, im finally se...   Feb 3 2009, 02:16 AM
914rrr   Here's all the aircooled VW type 1 and type 4 ...   Feb 8 2009, 03:43 AM
23 User(s) are reading this topic (23 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 06:13 PM
