> What do you have for chassis stiffening?
What is neccessary to race on slicks
Engman/ long kit [ 22 ] ** [25.00%]
Patrick Motorsprts kit/ Rear engine area [ 2 ] ** [2.27%]
Both [ 4 ] ** [4.55%]
Cage only [ 21 ] ** [23.86%]
All of the above [ 10 ] ** [11.36%]
None [ 12 ] ** [13.64%]
Other [ 16 ] ** [18.18%]
What is chassis stiffening? [ 1 ] ** [1.14%]
Do you race on slicks? (I guess its not racing if your not)
yes [ 34 ] ** [38.64%]
no [ 54 ] ** [61.36%]
Total Votes: 176
Guests cannot vote
Justinp71
post Sep 29 2008, 07:14 PM
I put some more horsepower in my car, so far I have just autocrossed it on street tires. I have the bolt in roll bar that has the mid bar going to the floor.
Besides that my chassis is stock and I am wondering what I should do for more re-enforcement... so I can comfortably run on slicks.
Below is a photo of the roll bar. I don't consider the roll bar to give to much chassis stiffening, but it just might help with cracking the longs.
Edit: I mainly just use the car for street and the occasional Autocross or DE
charliew
post Jan 16 2009, 08:48 AM
What makes these little cars attractive is their light weight. But the power levels when they were designed was lower and the tire tech has gotten so much better. The tricky thing is to only add as much support as is necessary to the exact weak spots that are known. This is where you originally started your quest. You seem to be off to a good start as the some of the smart guys have already assisted you a lot.
I would bet that in a lot of cases the fractures started before the reinforcements were added. You know some of these cars started as just two or three times a year racers and then bigger and sticker rubber was added and then more power and so on till it got serious and the cracks started appearing so then the repairs and stiffening started where it was obviously needed but then that moved the stress to the next weakest area and so on. If you start out knowing what the bad areas are and brace them before the stress is applied it will end up much better.
I know this is what you are doing and the reply about the cage tieing the cab up tight helped the long area a lot. The suspension ears are a problem all by themselves and need to be braced and thickened to spread the load out over a larger area.
I would like to do a permanent brace from the targa to the windshield but I don't think the windshield is strong enough as it is. I don't think there is enough room for a cage in a street car without wearing a helmet all the time. But that is the best bracing solution. Of course a exoskeleton would be the best but how stupid would that look on a street car.
I have lots of studying to do it seems.
The safest thing is to do the mods you listed and only run about 9 inch wide tires and keep the power below 250.
I find it hard to believe that these cars don't get real crooked on a rotisserie when the whole long is cut out on one side even with the diagonal brace that is used between the seat belt point and the kick panel.
I may persue the idea of a 1-1/4 tube cage that is tight up against the body at the windshield and targa and nothing overhead on the outside but two connecting tubes in the middle away from your head. This would not be as good as over the side windows but would be where maybe your head couldn't contact it in a wreck with the seatbelt on. I would also like to angle the windshield back some and that means a lower roof line but that might be asking too much.
I'm only 5'8" but both my sons are taller and they may want this car when I'm done with cars.
I have fieros and both my son's think they are too confining although I know some 6 footers with fieros.
These cars are very thin sheetmetal boxed sections and sometimes the spot welds are not as good as the engineers planned. Seam welding is the time proven helper on all unitized cars used in motorsports. I know the seam sealer is a pain but it might have come loose because of some of the twisting, where it's loose might give a indication of where the most twist is at stock levels.
Justinp71   What do you have for chassis stiffening?   Sep 29 2008, 07:14 PM
SirAndy   I've got a full cage but it's not tied int...   Sep 29 2008, 09:04 PM
sww914   Judging from the cars that I've fixed, if you ...   Sep 29 2008, 11:40 PM
dlestep   ...I am welding the rear stiffening kit on my car ...   Sep 29 2008, 11:42 PM
Justinp71   ...I am welding the rear stiffening kit on my car...   Oct 1 2008, 10:38 AM
Joe Ricard   Engman longs and a roll bar tied to rear shock tow...   Sep 30 2008, 05:57 AM
Justinp71   Thanks guys! <_< It sounds like for t...   Sep 30 2008, 07:07 PM
dakotaewing   I have Brad Maures (sp) Outer Long kit, and Chris...   Sep 30 2008, 10:10 PM
Justinp71   I have Brad Maures (sp) Outer Long kit, and Chris...   Sep 30 2008, 11:05 PM
jcd914   OK I guess maybe I should not be voting since the ...   Sep 30 2008, 11:59 PM
Justinp71   Well Thanks for posting anyhow Jim! When you ...   Oct 1 2008, 10:37 AM
the4u2   how much flex is to much? have one that flex 8mm ,...   Oct 1 2008, 01:07 PM
J P Stein   There are a pee pot load of do-dads sold to make y...   Oct 2 2008, 08:58 AM
9146986   The last full project car I built had Brad Mayeur...   Oct 2 2008, 08:59 AM
naro914   I've been racing or DEing our 914 since 1994, ...   Oct 2 2008, 08:14 PM
Justinp71   Does the Engman kit reduce body flex? Or just keep...   Oct 3 2008, 04:20 PM
jcd914   Does the Engman kit reduce body flex? Or just kee...   Oct 11 2008, 08:56 PM
ConeDodger   Does the Engman kit reduce body flex? Or just kee...   Dec 4 2008, 10:47 PM
John   An area that seems to crack and few discuss is whe...   Oct 23 2008, 08:28 PM
J P Stein   Tieing in the longs to the towers is gud. Tieing i...   Dec 7 2008, 02:30 PM
Justinp71   Well my conclusion for my more street oriented car...   Jan 14 2009, 01:20 AM
9146986   I forgot to add that I welded up all the seams I c...   Jan 14 2009, 10:06 AM
Justinp71   Did you race or a/x the car that you are describin...   Jan 14 2009, 12:22 PM
9146986   The customer that I built the car for did autocros...   Jan 14 2009, 12:37 PM
Justinp71   No cage, correct?   Jan 14 2009, 01:53 PM
charliew   What makes these little cars attractive is their l...   Jan 16 2009, 08:48 AM
Simon Tibbett   I am new to 914's and looking into getting one...   May 29 2009, 10:13 AM
jt914-6   I have Brad's long. kit, GT kit, boxed trailin...   Jun 1 2009, 08:50 AM
jhadler   In the first photo there, it looks like you are dr...   Jun 1 2009, 02:11 PM
jt914-6   Josh, yes I'm using the cooler heat for the wi...   Jun 1 2009, 03:25 PM
J P Stein   After bonking my helmeted haid on my cage halo, I ...   Jun 8 2009, 05:47 PM
Joe Ricard   JP would you please show me your engine lid? Lik...   Jun 9 2009, 05:51 AM
J P Stein   I don't have a pic of it, go figure. I made a ...   Jun 9 2009, 07:38 AM
Joe Ricard   Metal? My car will have bare minimum of metal....   Jun 9 2009, 09:15 AM
J P Stein   Metal? My car will have bare minimum of metal...   Jun 9 2009, 11:13 AM
Joe Ricard   Yea PM me with your thoughts. I'm a looking a...   Jun 9 2009, 11:26 AM
J P Stein   Yea PM me with your thoughts. I'm a looking ...   Jun 9 2009, 02:51 PM
Chris Hamilton   Has anyone measured the amount of flex they had be...   Aug 30 2009, 05:36 PM
Britain Smith   Didn't measure it, but we felt it in JP's ...   Sep 17 2009, 11:54 AM
Joe Ricard   I can 3 point lift my car and it stays level. get...   Dec 9 2009, 07:11 AM
Chris Hamilton   Joe, My car does that with an autopower rollbar bo...   Dec 12 2009, 03:55 PM
J P Stein   It doesn't take an engineering degree to see ...   Dec 12 2009, 07:01 PM
Randal   It doesn't take an engineering degree to see...   Dec 12 2009, 10:05 PM
J P Stein   I've taken JP's approach on adding fro...   Dec 13 2009, 11:06 AM
Randal   It doesn't take an engineering degree to se...   Mar 31 2014, 07:59 PM
Chris Hamilton   It doesn't take an engineering degree to see...   Dec 13 2009, 03:02 PM
J P Stein   I've been building stuff for 40 odd years....m...   Dec 13 2009, 04:00 PM
Joe Ricard   Chris there is no way your bolt in autopower cage ...   Dec 13 2009, 05:14 PM
J P Stein   BTW, our trip down to your house at Marina was qua...   Dec 13 2009, 05:56 PM
Chris Hamilton   JP, it will be fun to see how Andrew and Britain d...   Dec 13 2009, 07:05 PM
J P Stein   Brit is headed down that way for the SD National T...   Dec 14 2009, 08:30 AM
Joe Ricard   Raced in the little pond yesterday. PCA had an ev...   Dec 14 2009, 10:52 AM
Randal   Raced in the little pond yesterday. PCA had an e...   Mar 31 2014, 08:02 PM
Joe Ricard   Geeze I was reading this thinking wtf did I do? ...   Apr 1 2014, 05:53 AM
Randal   Geeze I was reading this thinking wtf did I do? ...   Apr 1 2014, 01:35 PM
smokey   My Lilbasterd Gets much stiffer wen chancing any...   Jan 5 2015, 08:17 PM
ThePaintedMan   Dafuq?   Jan 6 2015, 07:51 AM
Bullethead   How did this thread get reanimated? Last post was ...   Sep 6 2023, 09:45 PM
d914   egman inner longs tangering racing rear console su...   Oct 9 2023, 01:13 PM
mlindner   I had a full roll bar cage for many years. The las...   Dec 1 2023, 04:35 PM
brant   I had a full roll bar cage for many years. The la...   Dec 2 2023, 08:31 AM
mlindner   Thanks brant. Was not intended for full racing. D...   Dec 4 2023, 09:02 AM
Charles Freeborn   A 911 I'd be concerned about straying too far ...   Jan 6 2024, 01:24 AM
brant   We learned a lot about rules during the build. so ...   Apr 26 2024, 01:43 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:44 AM
