jc914 |
Member ![]() ![]() Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States ![]() |
I just changed the spark plugs after 7 years from my mechanic when i pulled them they were Bosch Platinum ( a no no for our cars) so i replaced them with Bosch wr7cc. I also changed the distributor cap, rotor, (cables were in great conditions). I also connect a Oil Pressure gauge and a CHT Gauge (connected it to cylinder 3).
The car has a Pertronix IgnitorI. The old Coil had a resistor on top. I replaced it with a Bosch blue Coil. when I reconnected the cables the car would not start. (IMG:style_emoticons/default/chair.gif) I think what happen was I connected the Positive black wire from the ignition to the negative side of the coil. When I reconnected: Red cable from the Pertronix to + of coil all black cables to Negative of coil (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) REWIRED to ( after reading some post) Red cable from the Pertronix to + of coil Solid Black cable to + of coil Black cable with purple strip to negative of coil Tach cable Black cable from Pertronics to Negative of Coil Did I Fried the Pertronix Ignitor. I tested the coil after re wired and with the ignition on it gives me i think 12v. Is there any way to test the pertronix to see if it is fried if it is I want to buy the Pertronix IgnitorII I went to there website and they have many which model to i get http://www.shopatron.com/index/pg=3/591.0.26484.26486.0.0.0 or is the Crane Cams 700-0300 a better option THANKS JC |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I just changed the spark plugs after 7 years from my mechanic when i pulled them they were Bosch Platinum ( a no no for our cars) so i replaced them with Bosch wr7cc. I also changed the distributor cap, rotor, (cables were in great conditions). I also connect a Oil Pressure gauge and a CHT Gauge (connected it to cylinder 3). The car has a Pertronix IgnitorI. The old Coil had a resistor on top. I replaced it with a Bosch blue Coil. when I reconnected the cables the car would not start. (IMG:style_emoticons/default/chair.gif) I think what happen was I connected the Positive black wire from the ignition to the negative side of the coil. When I reconnected: Red cable from the Pertronix to + of coil all black cables to Negative of coil (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) REWIRED to ( after reading some post) Red cable from the Pertronix to + of coil Solid Black cable to + of coil Black cable with purple strip to negative of coil Tach cable Black cable from Pertronics to Negative of Coil Did I Fried the Pertronix Ignitor. I tested the coil after re wired and with the ignition on it gives me i think 12v. Is there any way to test the pertronix to see if it is fried if it is I want to buy the Pertronix IgnitorII I went to there website and they have many which model to i get http://www.shopatron.com/index/pg=3/591.0.26484.26486.0.0.0 or is the Crane Cams 700-0300 a better option THANKS JC You killed the petronix...get a set of points. The cost 4 bucks. Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 03:06 AM |
