jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
Well.. I found out why the hood sticks up on the corners, And Im not sure if its fixable. By pushing down on both corners I figured out why there was all that lumpy paint along the bottom edge of the front trunk. (IMG:style_emoticons/default/sad.gif) The PO did a real nice paint job under there, I guess I did not pay that much attention.
Anyway... what do I do now??? fix it or get a new hood? Attached image(s) ![]() ![]() |
jsayre914 |
(IMG:style_emoticons/default/dry.gif) Well, the next hood never fits as good as the first one. I used the technique to bend down the passenger side front next to the eyelid. But the problem is when i looked at the side profile from the drivers side, the hood arched up in the center right over the fender. you cant really tell in the pic but i could get two fingers under the hood while it was closed (IMG:style_emoticons/default/sad.gif) reason was after closer inspection there was a dent in the hood frame on both sides right in the middle.
anyway .. here is what i did It worked perfect. I used a bunch of towles a crowbar and three small c-clamps... first i opend the lid and laid a bunch of towles the lenght of the fender, next i folded a towl and placed it along the edge of the top drivers side hood, then i took a large crowbar and held it up to the bottom edge of the hood, there was a almost one inch gap in the middle of the crowbar and it was touching the underside of the hood at both ends, i placed a clamp in the center untill it was tight and then i used one 6 inch on both sides and kept tightening every other one untill the gap from the crowbar to the hood was 1/4 inch and then repeated this proceadure for the other side. (IMG:style_emoticons/default/biggrin.gif) perfect fit |
Lo-Fi Version | Time is now: 24th June 2024 - 11:49 PM |
