> Carbon Monoxide in the Car, i think i'm dizzy
nebreitling
post Jan 21 2004, 12:04 PM
Member Emeritus
my girlfriend says she gets a headache after we drive the teener. i haven't noticed it before, but yesterday i felt a bit 'ill' after an hour drive -- even with the top off. the heater blower fan has always stayed off. (welcome to cali)
about 6 months ago i put some used late-model HE's on the car. they appeared very sound, with no apparent leaks on the inner exhaust tubes. i don't think i have an exhaust leak, but i'll be sure to double check everything. what are other sources of carbon monoxide? would a torn up heating air hose let in gas from the engine compartment? even with no blowers on?
any thoughts appreciatted. thanks, nathan
p.s. yeah, i know the late HE's suck. saving for header.
RustyWa
post Jan 22 2004, 12:13 AM
Working Member
I sure hope they are not the HE's....since I sold my old ones to Nathan. (IMG:style_emoticons/default/sad.gif) I don't recall ever having exhaust fume problems with them.
They were in pretty good shape, pretty clean inside and out. At the tail end of the exchangers, where it crimps around the single tube, that part is loose. I always used a large hose clamp to keep it in place. JB weld might have been a better solution.
One thing you could do to test, is disconnect all the tubing to the cabin and see if the fumes go away..that should help narrow it down.
(I didn't need these HEs anymore since I backdated my system.)
Here's a photo of the ends....
nebreitling   Carbon Monoxide in the Car   Jan 21 2004, 12:04 PM
!   You always use a home CO detector in the cab.....i...   Jan 21 2004, 12:13 PM
Mark Henry   Check it out for sure! But it may be leaking ...   Jan 21 2004, 01:19 PM
Jeroen   That's scarry shit! What ever it is, trace...   Jan 21 2004, 04:47 PM
nebreitling   that's a good idea about the CO monitor. migh...   Jan 21 2004, 05:15 PM
redshift   If the car is running rich, and you sit in traffic...   Jan 21 2004, 05:29 PM
nebreitling   ...   Jan 21 2004, 05:36 PM
efrenv   It could be the two (2) air dampers underneath the...   Jan 21 2004, 05:43 PM
nebreitling   that makes great sense. thanks.   Jan 21 2004, 05:58 PM
Targa   I also have a 75' 2.0 and it used to do the sa...   Jan 21 2004, 06:13 PM
SirAndy   as said above, the hose (or better the lack of) in...   Jan 21 2004, 06:40 PM
nebreitling   Andy et al, thanks so much for your thoughtful rep...   Jan 21 2004, 07:10 PM
RustyWa   I sure hope they are not the HE's....since I s...   Jan 22 2004, 12:13 AM
nebreitling   just a quick update on the CO mess: i capped the ...   Jan 25 2004, 01:24 AM
McMark   I got some 1.7 HEs and a hanger I'll let go RE...   Jan 25 2004, 01:31 AM
nebreitling   will they bolt right up to my 2.0? all i'd be...   Jan 25 2004, 01:40 AM
rhodyguy   the inlet to the muffler is completely dif on the ...   Jan 25 2004, 08:52 AM
DNHunt   Don't mess with CO. the problem is CO doesn...   Jan 25 2004, 10:00 AM
Demick   If you are planning to chop the HE's short and...   Jan 25 2004, 10:22 AM
McMark   The early exhaust will bolt up fine. You just nee...   Jan 25 2004, 03:00 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 07:25 AM
