> Aftermarket TypeIV motor mounts, ...anyone have lightweight solid mounts?
Chris Hamilton
post Jan 22 2009, 05:40 PM
Anyone here have leads on aftermarket motor mounts? I think I remember SirAndy having one made of box chromoly when he was still running a 4-banger. I'm looking for something solid and lighter than the stock bar.
McMark
post Jan 23 2009, 01:45 PM
914 Freak!
Eric, rotational stress along the length should occur between the center and the ends. There will never been end to end torsion, because the body is relatively solid (for the purposes of this design study). So you have a 1.75' section that's twisting, which is pretty short. I think the T-structure will provide sufficient strength.
Torsion comparisons between this design and the stock bar would be fairly easy to conduct. Drilling holes would also be an option that could be tested....
Chris Hamilton   Aftermarket TypeIV motor mounts   Jan 22 2009, 05:40 PM
Mark Henry   For the rubber mounts I wouldn't run anything ...   Jan 22 2009, 05:48 PM
Chris Hamilton   For the rubber mounts I wouldn't run anything...   Jan 22 2009, 08:02 PM
J P Stein   This is for my trailered racecar, you might hav...   Jan 23 2009, 10:08 AM
Aaron Cox   Make a pair on the lathe, shouldnt take you more t...   Jan 22 2009, 08:04 PM
SGB   Its been done. I think the weight savings were pr...   Jan 22 2009, 08:29 PM
McMark   I wonder is a T bar would make it lighter. Four t...   Jan 22 2009, 08:38 PM
Chris Hamilton   McMark that sounds interesting. I'm not sure w...   Jan 23 2009, 09:44 AM
Racer Chris   Why would you want to lighten one of the lowest pa...   Jan 23 2009, 11:06 AM
Chris Hamilton   Why would you want to lighten one of the lowest p...   Jan 24 2009, 07:09 PM
McMark   Here's a mockup design.   Jan 23 2009, 01:22 PM
Chris Hamilton   Here's a mockup design. I like that design...   Jan 25 2009, 12:52 PM
SirAndy   the car still has a sideshifter and typical linka...   Jan 25 2009, 09:23 PM
Chris Hamilton   the car still has a sideshifter and typical link...   Jan 26 2009, 02:23 PM
SirAndy   If I remember correctly you had a tubular steel m...   Jan 26 2009, 02:25 PM
ericread   How does your design ensure there is no rotational...   Jan 23 2009, 01:29 PM
McMark   Eric, rotational stress along the length should oc...   Jan 23 2009, 01:45 PM
ericread   Eric, rotational stress along the length should o...   Jan 23 2009, 01:47 PM
Mark Henry   You will need a hole for the shift rod.   Jan 23 2009, 02:17 PM
J P Stein   BTW, if ya'll want a rematch, it'll be at ...   Jan 23 2009, 07:03 PM
Chris Hamilton   BTW, if ya'll want a rematch, it'll be at...   Jan 24 2009, 07:06 PM
J P Stein   BTW, if ya'll want a rematch, it'll be a...   Jan 24 2009, 07:21 PM
McMark   Clearance for the shifter wouldn't be too big ...   Jan 25 2009, 09:01 PM
ChrisNPDrider   I like the idea of a six-like mount for a TIV that...   Jan 26 2009, 12:25 AM
Jeff Bowlsby   Here is Paul Woodbury's (URY914) engine bar......   Jan 26 2009, 02:38 PM
Chris Hamilton   Here is Paul Woodbury's (URY914) engine bar.....   Jan 26 2009, 06:10 PM
- Lo-Fi Version Time is now: 6th January 2025 - 08:15 PM
