xperu |
TEXAS ![]() ![]() ![]() Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None ![]() ![]() |
Are any of you running single carb, if so what kind of set up do you have. thanks
BarberDave |
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest ![]() |
I have had all three types of carbs on my 914. ( Single 2 barrel , dual single barrel Weber 34 Itc's , and dual Weber 40's . ) Buy far the best running, performance, mileage, are the 40's. Single 2 barrel is dito on every thing said above. Dual single barrel is dangerous , some one will be killed with those on there 914 . Bite the bullet and get the 40 IDF's you will be a happy camper. Or use the factory fuel injection, the best choise , more H.P. better fuel economy. The choise is yours! My 2 cents Dave (IMG:style_emoticons/default/slap.gif) |
xperu |
(IMG:style_emoticons/default/smilie_pokal.gif) I have had all three types of carbs on my 914. ( Single 2 barrel , dual single barrel Weber 34 Itc's , and dual Weber 40's . ) Buy far the best running, performance, mileage, are the 40's. Single 2 barrel is dito on every thing said above. Dual single barrel is dangerous , some one will be killed with those on there 914 . Bite the bullet and get the 40 IDF's you will be a happy camper. Or use the factory fuel injection, the best choise , more H.P. better fuel economy. The choise is yours! My 2 cents Dave (IMG:style_emoticons/default/slap.gif) I have been thinking about installing the FI, what do you mean by some one will be killed with those on there 914, is there a fire danger. I am weighing the $ options on a car I have already spent a lot on. Currently I have a 2 barrel, but it just loads up in first gear and offen dies, it runs good in the higher gears. The weather has been cold here in the Houston area, could be the problem, maybe jets? Mike |
Lo-Fi Version | Time is now: 25th June 2024 - 12:03 AM |
